Electrolysis rust removal - Router Forums
 51Likes
post #1 of 61 (permalink) Old 03-28-2016, 08:33 AM Thread Starter
difalkner's Avatar
First Name: David
Default Electrolysis rust removal
There was some interest in another thread on using electrolysis so I thought I'd post how/what I did on my PM jointer rather than hijacking that thread. I am certain you can Google this and find many variations to this process but this worked for me so I'm good with my method, but feel free to chime in and show how you've done this.
A few years ago I picked up a PM 54A jointer found on CL. The jointer had been in a non-climate controlled storage building and subject to humidity so it had what I thought was surface rust. When I got it home I realized the rust was a little more than I had initially realized.
When I brought it home it looked like this (soaked with WD-40 in this photo) -
Kind of heavy in some areas -
Ugly spot there in front of the cutterhead, which doesn't look too good, either -
Here's the cutterhead out of the jointer -
What I have here is a towel wetted with water and baking soda. I don't remember how much but in a 5 gallon pail I think I used about 2 gallons of water and about 1/4 to 1/2 cup of baking soda. I wrung the towel out about 75% and placed a sacrificial sheet metal plate I picked up at Lowe's on top of the towel. Then I hooked my battery charger, one lead to the jointer and one to the metal plate. Then I placed some weight on the metal plate to make sure there was good contact. In this case I used some Honduras Mahogany cutoffs from some columns.
After about 3-4 minutes the amperage gauge goes to about nothing which indicates the towel is now dry and has done all it is going to do. This is after removing the towel and no additional effort applied to the bed other than using the same towel to wipe the bed where the rust was.
Far less rust, looks pretty good -
Here's the cutterhead wrapped in a rag and with bailing wire wrapped tightly to make sure there is good contact. I hooked the leads up, gave it 3-4 minutes, and pulled the rag off.
Here's the cutterhead after Electrolysis and a little buffing with a Scotch-Brite pad -
And here's the finished machine. Looks good, runs good, and not a lot of effort to clean up using this process.
Thanks for reading!
David
BrianS, JohnnyB60, JFPNCM and 24 others like this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is offline
post #2 of 61 (permalink) Old 03-28-2016, 08:41 AM
That's a great result. Does the positive lead go to the plate or to the rusted equipment?
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #3 of 61 (permalink) Old 03-28-2016, 08:45 AM
Thanks for reading!
David
thank you for posting...
post #4 of 61 (permalink) Old 03-28-2016, 08:53 AM Thread Starter
difalkner's Avatar
First Name: David
Positive to the plate, negative to the equipment. I don't remember if I tried it the other way or read somewhere to do it this way but it worked so if I have to do it again sometime I'll probably do it the same way.
David
Romans 3:23
post #5 of 61 (permalink) Old 03-28-2016, 09:45 AM
schnewj's Avatar
The Negative should always be attached to the piece being de-rusted, so that the metal transfer, (replacement), is to the rusted item. If you do it the other way, Positive to the rusted piece, the metal transfer will be to the sacrificial plate/rod.
I use a five gallon bucket to de-rust hand plane bodies when I refurbish them.
This is a really innovative way to de-rust large flat surfaces...THANKS!
JohnnyB60, R÷ENTGEEP and Murtu01 like this.
schnewj is offline
post #6 of 61 (permalink) Old 03-28-2016, 12:58 PM
The results are stunning. Thanks for sharing that. I'd still like to kick the person in the butt hole who let it get that rusted to start with. It should be a crime to let that happen to a fine piece of machinery like that.
DaninVan, thomas1389 and cocobolo1 like this.
post #7 of 61 (permalink) Old 03-28-2016, 01:14 PM
Gaffboat's Avatar
First Name: Oliver
An amazing result! Thanks for the How-To.
Gaffboat is offline
post #8 of 61 (permalink) Old 03-28-2016, 01:25 PM
RainMan 2.0's Avatar
I amazed at the outcome . I thought that jointer was pretty much scrap metal in the beginning
Ok ,I never insulate
RainMan 2.0 is offline
post #9 of 61 (permalink) Old 03-29-2016, 07:00 AM
First Name: Larry
Amazing results.
Knot working is offline
post #10 of 61 (permalink) Old 03-29-2016, 09:03 AM
TenGees's Avatar
First Name: Paul
Yup, like Rick, I thought that was junk and look at it now! Very nice, thanks for the info David.
Roy Drake likes this.
TenGees is offline
Rust Removal From My Table Saw TOP Tagwatts1 Tools and Woodworking 68 03-28-2016 07:12 PM
Rust removal electrolysis, how to remove black DominikPierog DIY and Renovation 9 06-07-2015 01:27 AM
Electrolysis rust removal example GulfcoastGuy Tools and Woodworking 10 10-20-2013 10:28 AM
Rust removal on table saw luvmyretirement Tools and Woodworking 62 10-04-2009 07:58 PM
