Diamond Discs for Worksharp 3000 - Router Forums
 19Likes
post #1 of 18 (permalink) Old 03-29-2016, 05:28 PM Thread Starter
Default Diamond Discs for Worksharp 3000
I thought I would start this new thread on a continuation of the discussion on the Worksharp 3000 and diamond discs.
Thanks to Bill @schnewj , and his Post # 41, p.5, Router Forums - Router and Woodworking Discussion Community
And all the research Bill did to find a way to do the diamonds discs, that used to try this method.
1, cut some 6"X6" pieces of 1/2" MDF.
2. Drill hole in center and cut rounds on band saw, a brad point worked better for the hole than the forstner bit.
3.I used the same jig to sand the edges on the oscillating sander.
4. Layed a MDF disc on top of the rubber PVA backed magnetic disc and marked the hole location, then drilled them wit a 1/2" brad point bit.
5.Peeled the backing sheet off the magnetic disc and cut a short 1/2" dowel to guide it onto the MDF disc. When both sides were attached, clamp it in the vise to press the disc contact adhesive to the MDF good and tight.
\6. Remove from vise and insert the short dowel into the hole to guide the Diamond coated steel disc into place.
Do this to all the discs both sides and you are good to go.
Sharpening:
I made up a 180/260, 360/600, 1200/3000, Also have a 60, 80, 120, discs which I may make up later, I will have to order more Macnetic PCA discs tho.
First thing I found was that the retaining bolt and Knob on the WS 3000 was too short for the new thicker discs. So I had to make a new longer one with a jig knob I had from Peachtree.
The sharpening went very good, it is 50% faster than the sanding discs gave excellent results. less pressure is required on the disc, instead of 10 plunges and retractions, it was 5.
I did put the 3600 WS disc in to get a little more polish at the end.
Then I hand drew the chisel accross a smooth leather strop w/o any stropping solution and the improved the polish.
These are sharp tools ,folks. Thanks to Bill Scheider and all his excellent research. a real winner.
Here are some pictures
Herb Stoops is online now
post #2 of 18 (permalink) Old 03-29-2016, 05:30 PM Thread Starter
Here are the rest.
post #3 of 18 (permalink) Old 03-29-2016, 05:54 PM
Nice!
post #4 of 18 (permalink) Old 03-29-2016, 10:45 PM
First Name: lee
I wondered how this worked using the diamond discs on the Worksharp 3000.
coxhaus is offline
post #5 of 18 (permalink) Old 03-30-2016, 07:26 AM
First Name: Jesse
Nice job Herb! About how much was the additional cost to bring it up to this level of excellence?
LazurusLong is offline
post #6 of 18 (permalink) Old 03-30-2016, 08:11 AM
hawkeye10's Avatar
First Name: Don
Herb that is pretty neat. But then we expect that from you.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 18 (permalink) Old 03-30-2016, 08:53 AM
First Name: Johnny
Herb, where do you get these diamond discs?
OttoW likes this.
JohnnyB60 is offline
post #8 of 18 (permalink) Old 03-30-2016, 09:13 AM
schnewj's Avatar
Fantastic write-up Herb.
I, too, found that the hold down know was a little short, however, there is enough engagement that the original holds. Due to the rotation of the disc, the knob will tighten itself and will not loosen. I may make up one similar to what you did, but I've been lazy...
After using these plates for a while, I have found that the 3600 grit diamond plate has had a groove worn in one spot. The rest of the plate surface is fine, but the higher grits may not last for this application. The rest of the plate is still very usable for topside use.
The question was asked as to how much this costs. I'll refer you back to the original post for the set-up (http://www.routerforums.com/tools-wo...rp-3000-a.html). Basically, the DMT set-up is between $60-80. If you buy the mag plates and the diamond plates from the link source, the same set-up is roughly $35-40. This is for a two plate set-up. I suggest that you order five or more diamond plates at a time. The shipping cost is the same after five plates.
The diamond plates are true 6" plates. They are 1/10" bigger then the WS3000 glass discs...they work fine with no clearance issues.
I bought two additional glass discs off of eBay and applied the PSA backed magnet material. I then ran an X-acto knife around the disc to trim off the excess that was overhanging. I suggest that you do this, so, that, the magnetic material doesn't get snagged on something and get peeled back.
I have been meaning to cut out some MDF discs to try. I picked up the material the weekend before last, but have been "under the weather" (Springtime allergies). I plan on charging the MDF with buffing compound to act as a strop. I may even see about getting a piece of leather and gluing it to the MDF to make my own leather strop. Lots of experimenting to do, yet!
The whole downside to the WS3000 system is that it will not accept wider (2") iron. These have to be done on the top of the Disc. If you look at the stands (original linked thread) you will see stands that Desert Rat Tom and I each built. By leveling the disc to the platform, using a honing guide to maintain the desired angle, you can sharpen wider blades on the top of the disc. I have done this with great success.
Source links (post #50): http://www.routerforums.com/tools-wo...-3000-a-2.html
@Herb Stoops , thanks for following up.
Bill
JohnnyB60 likes this.
schnewj is offline
post #9 of 18 (permalink) Old 03-30-2016, 09:14 AM
First Name: Allen
Thanks for all the info on this sharpening system. I too wonder where you purchased the diamond discs? and how expensive were they? I could be helpful for those who don't want to invest in the Worksharp system that is a similar DIY sharpening system was developed by Stephen Ogle using rigid diamond discs (see
). They were purchased from an eBay company called Auctiva Emporium at ' - lau***''s Emporium - Home & Garden' and are of good quality and only cost $10-$20 each depending on size.
JohnnyB60, Murtu01 and Herb Stoops like this.
aganser is offline
post #10 of 18 (permalink) Old 03-30-2016, 11:23 AM Thread Starter
I got the PSA magnetic discs from http://www.magnetking.com/store/peel...dhesive-magnet
The diamond discs from Jade Carver ? Diamond Tools Gems Jade (9250 689-8840
Santa's present: Work Sharp 3000 DesertRatTom Tools and Woodworking 68 02-25-2016 07:01 PM
Work Sharp and chisels BrianS Tools and Woodworking 18 10-17-2015 04:23 PM
CNC Diamond Router Bits Costs rockysaw CNC Routing 11 08-29-2013 01:03 PM
Small Discs Jig prospector45 Jigs and Fixtures 16 12-10-2012 09:02 AM
How to fit ant-slip discs into hardwood floor jjay66 Router Bits - Types and Usage 7 10-26-2009 06:29 PM
