Glue Question - Router Forums
 17Likes
post #1 of 25 (permalink) Old 04-01-2016, 10:15 AM Thread Starter
berry's Avatar
First Name: Berry
Default Glue Question
I've been asked by a brother-in-law to make 'garden arbor' for his outside model railroad. The outdoor layout is in the White Mountains of Arizona. So sun, some rain and snow. I'm working from plans from a model railroading magazine, he provided.
I'm using cedar. The trellis pieces are 1/8" x 1/8" x 1 1/2" long. The legs are 1/4" x 1/4" x 4".
What kind of glue would you use? TB III or would some CA glue be better? or???
Thanks for reading and considering my question.
May the grain be ever in your favor.
berry is offline
post #2 of 25 (permalink) Old 04-01-2016, 10:22 AM
DonkeyHody's Avatar
First Name: Andy
I would use Titebond III. I think it's plenty weatherproof enough for this application.
berry likes this.
DonkeyHody is offline
post #3 of 25 (permalink) Old 04-01-2016, 10:42 AM
Bolts and nuts as much as possible, screws where those aren't practical. I've tried resourcinol and used PL400 which are both waterproof and the wood failed beside the joint in fairly short order. I have a pair of wooden benches which are twice as old as anything else I've done that were bolted together with galvanized bolts and the slats screwed down and then the counter bored screw holes plugged with tapered wooden plugs and they are badly weathered but still as solid as the day I built them. I covered the uprights on the benches with 1 x 6s which were blind doweled from the underside using dowel centers to locate the holes and those were glued on (don't remember with what anymore) and they quit holding and one board blew off. Water soaked right through the board and destroyed the bond.
BobJ3 used to say the say thing, mechanical fasteners instead of glue.
Ray Newman likes this.
post #4 of 25 (permalink) Old 04-01-2016, 10:45 AM
I would use non-water based glues such as a polyurethane glue and treating the wood as troublesome wood is a plus...
PL Premium would work better than most anything out there...
use sparingly as it expands as it cures.. mechanical fastening and/or clamps are a must...
mineral spirits/turpentine clean up while it's wet...
Loctite PL Premium Polyurethane Construction Adhesive from Loctite Adhesives
post #5 of 25 (permalink) Old 04-01-2016, 12:17 PM
Bodger96's Avatar
First Name: Bob
I know epoxy is more $ but I have never had a problem with any outdoor project coming apart.
Regards Bob
Bodger96 is offline
post #6 of 25 (permalink) Old 04-01-2016, 12:29 PM
Gaffboat's Avatar
First Name: Oliver
Ummm, guys? All your advice is good but did you miss the size he's working with? The legs are 1/4" x 1/4" x 4" and the trellis pieces are 1/8" x 1/8" x 1 1/2". At best he might be able to use #4 screws but I think for the miniature size of what's being built Titebond III will do just fine. If he's really concerned, some two-part epoxy would work well also.
berry, vchiarelli and PhilBa like this.
Gaffboat is offline
post #7 of 25 (permalink) Old 04-01-2016, 12:50 PM
Originally Posted by Gaffboat View Post
Ummm, guys? Your all your advice is good but did you miss the size he's working with? The legs are 1/4" x 1/4" x 4" and the trellis pieces are 1/8" x 1/8" x 1 1/2". At best he might be able to use #4 screws but I think for the miniature size of what's being built Titebond III will do just fine. If he's really concerned, some two-part epoxy would work well also.
duh...
at that small of pieces WRC or any cedar won't do well...
the wood it's self will quickly break down...
might want to pick another wood...
Black locust and dogwood would be excellent choices for AZ...
think hundred year old fence posts...
more choices...
African Ebony
Bald cypress (old growth)¹
Catalpa
Cherry, black
Chestnut
Cypress, Arizona
Junipers
Locust, black³
Mulberry, red³
Oak, bur
Oak, chestnut
Oak, Gambel
Oak, Oregon white
Oak, post
Oak, white
Osage-orange³
Redwood
Sassafras
Walnut, black
Yew, Pacific
¹The southern and eastern pines and bald cypress are now largely second-growth, with a large proportion of sapwood. Consequently, it is no longer practicable to obtain substantial quantities of heartwood lumber in these species for general building purposes.
³These woods have exceptionally high decay resistance.
berry likes this.
post #8 of 25 (permalink) Old 04-01-2016, 02:31 PM
Gaffboat's Avatar
First Name: Oliver
If the wood breaking down with exposure is a problem why not just the seal the whole thing with a thin coat of epoxy? The wood will still show through but it will be pretty impervious to the weather. The only major issue might be the epoxy breaking down from uv exposure. An alternative would be to use some marine varnish like Cetol to seal everything. That's what I used on my mast and other exposed wood when I built a sailboat. In any event, this sounds like a fun project and I'm looking forward to seeing photos of the finished piece, especially in situ.
vchiarelli likes this.
Gaffboat is offline
post #9 of 25 (permalink) Old 04-01-2016, 03:25 PM
I would worry more about the heat exposure separating the cedar's wood fibers and grain...
Herb Stoops likes this.
post #10 of 25 (permalink) Old 04-01-2016, 06:56 PM
I agree with Stick, treat the wood and use bolts like was previously stated ,don't waste time with any glue.
Herb Stoops is offline
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 11:21 AM
Router Table Top Glue Matthew C Smith Table-mounted Routing 18 05-03-2014 11:06 PM
Hide Glue Daikusan Tools and Woodworking 9 02-11-2014 07:47 AM
DC Question angus Lobby 3 03-31-2008 08:29 PM
