1959-60 Sears W'dworking Tools - Router Forums
 12Likes
post #1 of 14 (permalink) Old 04-01-2016, 10:10 PM Thread Starter
First Name: Ray
Default 1959-60 Sears W'dworking Tools
Brought back a few memories of going to Sears and looking at all the tools on display. The radial arm saws always impressed with all that it was supposedly able to do.
http://www.vintagemachinery.org/pubs/222/2876.pdf
Ray Newman is offline
post #2 of 14 (permalink) Old 04-01-2016, 10:54 PM
First Name: Keith
Interesting Ray...brings back so many memories of their tools that I owned at one time or another.
That was back in the day when they had pretty good tools as I recall, and their guarantee was decent as well.
About the scariest tool I had was their moulding cutter set. I was always worried every time I used it. For some reason I always thought that the cutters were going to fly out. But, of course, they never did.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #3 of 14 (permalink) Old 04-02-2016, 01:22 AM
There are a bunch of those tools I'd like to be able to buy for those prices now. I also have that moulding cutter and still use it occasionally.
post #4 of 14 (permalink) Old 04-02-2016, 03:45 AM
First Name: Scott.
Local workshop I've sometimes worked in has a Wadkin radial arm saw. Never been keen on that thing, especially just after its had a blade change as I'm not so sure the person changing it fully understands the implications of blade tooth rake.
demographic is offline
post #5 of 14 (permalink) Old 04-02-2016, 09:22 AM
First Name: Keith
In the early '70's I had a 10" Craftsman Radial arm saw. I was in the building business at the time and it was used on a daily basis. Only ever used it for crosscutting, although with careful setup it was supposed to be able to function for ripping as well. I never did try that because I always thought that it would be so easy for the blade to go out of alignment with the fence that serious binding would likely be inevitable.
I did witness such a problem on a job site and the wood being ripped was turned into a projectile, much the same as can happen on a table saw. No injury to anyone fortunately, but it scared us enough that I never dared try it.
post #6 of 14 (permalink) Old 04-02-2016, 10:34 AM
You can still get prices like that. It's called Harbor Freight.
Of course, the quality suffers a bit -- ok, a lot.
HJ
Still uses a Craftsmen TS from the day. Not fancy, but gets the job done.
honesttjohn is online now
post #7 of 14 (permalink) Old 04-02-2016, 11:03 AM
TenGees's Avatar
First Name: Paul
I never knew that they had metal working tools. I still use a Craftsman RAS, router, palm sander and I still like my old Craftsman screwdriver set. I looked on the Canadian site the other day... it seems they have more categories of tools listed than actual tools now.
cocobolo1 likes this.
TenGees is online now
post #8 of 14 (permalink) Old 04-02-2016, 11:57 AM
Most of the metal working machines,lathe, shaper, milling machines etc. were made by Atlas to Sears specs and were a lesser grade of material,i.e. potmetal in a lot of parts instead of steel that Atlas used in their machines.
But for garage mechanics they were great tools.
That was one of my childhood pastimes, reading the Sears tool catalogs and dreaming of the day I could own all those tools.
Herb Stoops is offline
post #9 of 14 (permalink) Old 04-02-2016, 12:31 PM
MEBCWD's Avatar
I still have one that is older than the fancy 1959 model in the catalog but looks very similar. I have a lot of the attachments that were made for them including a planner blade, molder and others. It belonged to my uncle who made most of the furniture in his house. He and I made several projects during the summer when I was growing up and used this same saw. When I got it I was told it was purchased around 1950 when I was born.
TenGees and firstmuller like this.
MEBCWD is offline
post #10 of 14 (permalink) Old 04-02-2016, 12:37 PM
I use the 60's RA saw on all my projects. I only use it for cross cutting. With a Freud 80t blade it gives a cut as smooth as glass.
And I use the Craftsman 12" table saw with Freud blades for ripping.
Greetings! CharlesWebster New Member Introductions 19 11-30-2015 07:01 PM
New to the forum Zwervertje57 New Member Introductions 7 06-06-2015 11:10 AM
Ordering Incra threw amazon.ca or directly threw Incra's USA location RainMan 2.0 Table-mounted Routing 20 05-20-2014 04:54 AM
Which tools for most jobs Bob N Tools and Woodworking 11 02-23-2009 12:04 PM
