Fabricated a z axis on legacy ornamental mill model 1800 - Router Forums
 8Likes
  • 5 Post By davefrommd
  • 1 Post By kp91
  • 1 Post By MEBCWD
  • 1 Post By davefrommd
post #1 of 10 (permalink) Old 04-03-2016, 11:35 PM Thread Starter
First Name: dave
Default Fabricated a z axis on legacy ornamental mill model 1800
i fabricated a z axis for my legacy ornamental mill model 1800 using 3/8" and 1/4" thick 6061 T6 plate aluminum, 1/4" x 1.25 6061 T6 angle aluminum. holes were drilled and tapped with 1/4-20 and 10-32 threads, and am using lock washers on every hex screw, should any screws work loose i will add loctite to the threads. i added 4 caster wheels with brakes to the legs, i changed the orientation of the router and am using a porter cable 3 1/4 horse power 7518 soft start electronic variable speed router. the z axis is a ball screw with an acme threaded rod used on cnc machines. i added a digital depth gauge and the router has 8" of downward travel. the machine seems to be a lot tighter with closer tolerances. the first picture is before and the next picture is after. i cut all the aluminum on my 12" dewalt 60 tooth carbide tipped power miter slider saw. it was the first time i cut aluminum, it cut the 3/8" thick plate aluminum very easily.
kp91, MEBCWD, Stick486 and 2 others like this.
davefrommd is offline
post #2 of 10 (permalink) Old 04-04-2016, 06:26 AM
kp91's Avatar
First Name: Doug
Looks awesome. Well made project, I especially like the digital indicator. A lot easier to use than feeler Gages I imagine.
MEBCWD likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 10 (permalink) Old 04-04-2016, 09:29 AM
that is awesome...
post #4 of 10 (permalink) Old 04-04-2016, 10:27 AM
MEBCWD's Avatar
Great Project for the shop!
I agree with Doug the addition of the digital indicator is a big plus when trying to make adjustment.
Now that you have it built I look forward to seeing some projects you make.
honesttjohn likes this.
MEBCWD is offline
post #5 of 10 (permalink) Old 04-04-2016, 04:35 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Very nice work, both your design and fabrication. N
neville9999 is offline
post #6 of 10 (permalink) Old 04-06-2016, 10:58 AM Thread Starter
First Name: dave
Default fabricating hand wheel shaft
I had to fabricate a steel shaft to go from 1/4" id to 1/2" od. i had some extra steel shaft laying around so i cut it to size, drilled out one end to 1/4" id using a cobalt drill bit made by dewalt. I drilled out holes for the hex set screws and tapped them to 10-32 and 1/4-20.
Stick486 likes this.
post #7 of 10 (permalink) Old 04-06-2016, 11:25 AM
you have talent....
post #8 of 10 (permalink) Old 04-06-2016, 01:53 PM
you have talent....
I'll second that!!!!
HJ
honesttjohn is online now
post #9 of 10 (permalink) Old 04-11-2016, 05:00 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Dave.
Congratulations!!! I like the hand-wheel system. Maybe I´ll copy that for my homemade machine.
We, woodworkers are everywhere!!!
papasombre is online now
post #10 of 10 (permalink) Old 04-15-2016, 08:20 PM Thread Starter
First Name: dave
i bought the hand wheel on ebay, it had a around 1" inside diameter and no set screw, i filled in the 1" hole with some paste epoxy with metal and drilled out a 1/2" hole, then drilled and taped 10-32 holes for the set screw, the hand wheel is solid aluminum. i can remove the hand wheel any time and add a stepper motor if i wanted to. i think the hand wheel is 5" or 6" diameter.
Need owners installation manual for Legacy ornamental mill model 1800 davefrommd Tools and Woodworking 11 11-24-2018 02:25 PM
For Sale: Legacy Ornamental Mill Model 1800 RWeigant Woodworking Classifieds 5 03-11-2017 10:17 PM
router mount delrin or aluminum? for model 1800 legacy ornamental mill davefrommd Tools and Woodworking 6 02-27-2016 02:17 PM
For Sale: Legacy Ornamental Mill, Model 1800 TruckeeWoodworker Woodworking Classifieds 0 09-12-2013 03:15 PM
