What should be the next tool? - Router Forums
 8Likes
post #1 of 32 (permalink) Old 04-06-2016, 09:51 PM Thread Starter
TWheels's Avatar
Default What should be the next tool?
I have two routers, a drill press, a miter saw and a 7 inch circular saw. I do not feel that affordable table saws are safe. I am considering band saws the most expensive of which is the Laguna 14 inch, and I am looking at others such as the Grizzley line and the Shop Fox 14 inch with the extenders.
Am I thinking along the right lines or should I be looking at other things? I generally use big box lumber or local retail places; I am not aware of any lumber yards. I am an amateur hobbyist woodworker who first learned about router use from the Router Workshop and consider myself a student of Honored Member Harry.
One other consideration for those who do not know is that I am a paraplegic so live in a wheelchair.
Thanks very much.
Vegetarian Arthritic Paraplegic Wannabe Routerologist
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
post #2 of 32 (permalink) Old 04-06-2016, 10:11 PM
I have Laguna (Italian made) and it is one fine piece of equipment...
consider this table saw w/o the stand to make it friendlier/safer to use... (make your own stand)...
Bosch GTS1041A REAXX? Jobsite Table Saw Takes User Safety to the Next Level and Also Saves the Blade | Business Wire
https://www.boschtools.com/us/en/bos...a-09-113798-p/
post #3 of 32 (permalink) Old 04-06-2016, 10:26 PM Thread Starter
TWheels's Avatar
Thanks @stick . Looks very promising. Any idea about the price?
post #4 of 32 (permalink) Old 04-06-2016, 10:55 PM
It depends a lot on what type projects you like doing Tom but I can see a table saw being a problem because it requires a pretty good reach across if you are seated. Maybe a power feeder would solve that but small saws aren't really sturdy enough for them and they cost about the same as a small saw.
I saw a Laguna BS at a woodworking show and I agree with Stick. It's almost like comparing a Corvair to a Cadillac compared to most other saws. I couldn't see any vibration so I put my hand on the frame and I couldn't feel any vibration either. The one odd thing I find about all bandsaws I've seen is that they are set up better for a left hander than a right hander. You could get close enough to the blade to work comfortably while seated but they aren't really made for sawing straight over any distance.
One machine that would be perfect for you is a scroll saw. Have you ever thought about scroll work? Everyone sits to do it.
post #5 of 32 (permalink) Old 04-06-2016, 11:06 PM
vchiarelli's Avatar
First Name: Vince
Tom
As Charles says, the type of project you like to work on will really determine the tools that would be best suited.
However, I would also ask, have you considered hand tools? Power tools aren't the be all, end all and you can do some pretty good work without them.
vchiarelli is offline
post #6 of 32 (permalink) Old 04-06-2016, 11:18 PM
First Name: Ray
On the saws your are considering, how high are the tables from the floor?
Too high and it will be very awkward or not possible to use and some cabinets can not be cut off/altered to lower the table height.
Ray Newman is offline
post #7 of 32 (permalink) Old 04-06-2016, 11:46 PM
elevated floor...
post #8 of 32 (permalink) Old 04-06-2016, 11:49 PM
sorry...
no I don't...
post #9 of 32 (permalink) Old 04-07-2016, 01:51 AM
First Name: Ray
Stick: what do you mean by an "elevated floor"?
post #10 of 32 (permalink) Old 04-07-2016, 05:41 AM
paduke's Avatar
Tom
Chuck said it right A scroll saw can add a lot to a hobbyist work shop. I use mine often when making templates. Costs wise I see them all the time on craigs list
paduke is offline
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 04:33 PM
Chinese W1325ATC CNC - tool positioning semenov419 CNC Routing 2 01-29-2016 09:48 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 11:12 PM
Peak HP dgcutter General Routing 22 01-10-2013 09:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-08-2012 12:17 AM
