Checking TS sled for square - Router Forums
 2Likes
  • 1 Post By jdonhowe
  • 1 Post By Stick486
post #1 of 10 (permalink) Old 04-13-2016, 08:00 AM Thread Starter
Default Checking TS sled for square
This method would seem to be quicker than the normal "5 cut" method of checking a table saw sled for square - just drag out the trusty dial indicator
https://atelierdubricoleur.wordpress...oupe-panneaux/
The framing square, obviously, would have to be square, but everyone learned how to do that with a center punch and a sharp pencil.
tomp913 is offline
post #2 of 10 (permalink) Old 04-13-2016, 08:14 AM
vchiarelli's Avatar
First Name: Vince
Tom
When I made my panel sled I used that method with a good machinist's square. A lot easier and quicker than the 5 cut method.
vchiarelli is offline
post #3 of 10 (permalink) Old 04-13-2016, 08:44 AM
BernieW's Avatar
First Name: Bernie
I also used a machinist square. A lot easier and just as accurate IMHO as the 5 cut.
Bernie W.
To succeed in life, you need three things: a wishbone, a backbone and a funnybone.
BernieW is offline
post #4 of 10 (permalink) Old 04-13-2016, 10:48 AM
Ghidrah's Avatar
First Name: Ronald
I used 2 12" long drafting triangles, 2 grip tite magnetic feather boards and a 10" calibration disk. Everything was good and I never thought anything about it for close to 5 yrs, then I heard of the William Ng's 5 cut test. To my surprise, (by my caliper) I was a smidge over his result, more than good enough at 18"
Ghidrah is offline
post #5 of 10 (permalink) Old 04-13-2016, 11:11 AM
Here's a quick video showing how to do it:
I agree with using either machinist or drafting squares over a carpenter's square. While I can get mine square, I'm not convinced the edge is truly straight- mine, anyway, is certainly not very smooth, and gives the dial indicator (and me) fits
tomp913 likes this.
jdonhowe is offline
post #6 of 10 (permalink) Old 04-13-2016, 11:52 AM
same here...
BernieW likes this.
post #7 of 10 (permalink) Old 04-14-2016, 04:30 PM
First Name: Keith
Originally Posted by BrianS View Post
Of course, once you have it made, you will probably discover that it's not big enough.
Either that, or you will end up making two or three for more specific purposes.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #8 of 10 (permalink) Old 04-14-2016, 06:14 PM
Knothead47's Avatar
I've not seen a carpenter use a square. Used to sell cabinetry and never saw one on a jobsite in 2-1/2 years. But......it was obvious how houses were constructed.
Thanks for the video. I bought a Groz square at Woodcraft a while back. Surprisingly, my 12 inch Brown and Sharpe square is right on the money, according to Mr. Groz. Mr. Groz is consulted a lot in my shop.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
post #9 of 10 (permalink) Old 04-14-2016, 06:21 PM
hawkeye10's Avatar
First Name: Don
I bought a new Jet TS a few months ago and haven't built a sled for it. I need a sled and the video will help me make it right.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 10 (permalink) Old 04-16-2016, 08:55 AM
Ghidrah's Avatar
First Name: Ronald
A framer only requires a framing square for cutting rafters and stair stringers.
Ghidrah is offline
Save-Your-Time Saw Sled NickyP Show N' Tell 34 11-17-2015 04:43 PM
Combining The Incra LS Positoning Systeprem To The Express Sled Jerry Bowen Tools and Woodworking 8 03-11-2014 06:39 AM
coping sled advice dickhob Table-mounted Routing 2 05-18-2012 11:18 AM
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 11:14 AM
Table saw sled.......... Duane867 Tools and Woodworking 5 07-29-2009 08:59 PM
