2-3/4" Holes in Plywood - Router Forums
 21Likes
post #1 of 38 (permalink) Old 04-19-2016, 06:02 AM Thread Starter
Default 2-3/4" Holes in Plywood
I have to cut a number of 2-3/4" holes in 3/4" plywood. The options I'm considering are a Forstner bit, a hole saw, or an adjustable hole cutter, as in the picture below. The reviews on all of these products are all over the place. The Forstner bits look like they will dull quickly in plywood. Hole saws are slow to cut, but they're pretty durable. I've never used a hole cutter. For the record, I don't know how to sharpen bits, so I'd like to know which bit will last the longest. The hole cutter has a lot of appeal because it is infinitely adjustable. Which way should I go?
Scotty: I can't change the law of physics! I've got to have 30 minutes!
patlaw is offline
post #2 of 38 (permalink) Old 04-19-2016, 06:08 AM
Nickp's Avatar
First Name: Nick
Forstner bit will tear at the bottom...
Circle cutter might also...and will grab as grain changes...not really meant for deep cuts...
Hole saw has my vote...
Drill press...?
Herb Stoops and gjackson52 like this.
Nick
Nickp is offline
post #3 of 38 (permalink) Old 04-19-2016, 06:23 AM
have the hole cutter...
not so good...
better forstner bits w/ serrated/toothed rims and an in carbide will outlast you...
1 to 4 tooth hole-saws (Lenox or Bosch) are for wood...
mega toothed saws are for metal but will do wood...
these saws are everywhere...
Stick486 is offline
post #4 of 38 (permalink) Old 04-19-2016, 06:25 AM
Drill press...?
serrated bit and a backer will put a stop to that...
Stick486 is offline
post #5 of 38 (permalink) Old 04-19-2016, 06:28 AM
First Name: Phillip
Forstner bit is your best bet. You can place a sacrificial piece under your work to prevent tear out.
Hole cutters are clunky to set up and run. You'll get some variation in your diameters. I have one that dulls very quickly. A forstner bit will last a long while.
gacatron and cocobolo1 like this.
To change the world, change your mind.
phillipdanbury is offline
post #6 of 38 (permalink) Old 04-19-2016, 06:43 AM
Contributor of the Month
RotoZip type tool will also work. It's a specialized tool so not something you'd want to buy for a one-time project. How large are the pieces that you need to cut the holes in?
JIMMIEM is offline
post #7 of 38 (permalink) Old 04-19-2016, 06:52 AM Thread Starter
Yes, I have a drill press. There are 12 holes in a 16x20 piece of 3/4" plywood.
patlaw is offline
post #8 of 38 (permalink) Old 04-19-2016, 06:58 AM
fostner...
Stick486 is offline
post #9 of 38 (permalink) Old 04-19-2016, 07:06 AM
Make a template. Rough cut the holes and finish with a flush trim bit in a router.
JIMMIEM is offline
post #10 of 38 (permalink) Old 04-19-2016, 07:21 AM
dalboy's Avatar
First Name: derek
I would go this route as well, as I feel it would leave cleaner holes
bcfunburst and Semipro like this.
dalboy is offline
3/4" bench dog holes. jock37 New Member Introductions 8 07-11-2014 07:46 PM
cutting 3/4" plywood towtalsa Router Bits - Types and Usage 11 09-14-2012 02:06 AM
Can I use 3/4" Plywood for Sliding Closet Doors? redzone Tools and Woodworking 6 03-01-2012 09:51 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Rabbeting 3/4" plywood edge WoodenShoe Table-mounted Routing 3 06-13-2006 01:15 PM
