Thin kerf saw blades??? - Router Forums
 10Likes
post #1 of 20 (permalink) Old 05-01-2016, 07:53 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Thin kerf saw blades???
I have an Infinity thin kerf saw blade ".097". I was wondering what your opinion is for these thin kerf blades. I have heard they deflect and vibrate more than .125 blades. Is this a problem?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 20 (permalink) Old 05-01-2016, 08:24 AM
Gene Howe's Avatar
First Name: Gene
I've been using Freud 24 T thin blades for ripping 8/4 white oak and have not seen any deflection.
I'm wondering if those who do see deflection and/or vibration have a saw with a slight arbor defect.
Herb Stoops likes this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 20 (permalink) Old 05-01-2016, 08:24 AM
First Name: Keith
There's two sides to that argument.
Firstly, the blade removes less wood than the thicker blade, which makes it easier to push wood through your saw.
The flip side is that if you are cutting difficult wood, the blade will tend to heat up more, which in turn causes the edge of the blade to expand slightly. This is what gives the blade that characteristic wobble.
I find that if you make sure the blade is kept sharp and you don't push it too hard, that the blade will stay flat and do an excellent job. Don't be tempted to run the blade once you notice that it is starting to dull and you should be fine.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #4 of 20 (permalink) Old 05-01-2016, 08:30 AM
First Name: Keith
Gene, you beat my post by a few seconds.
Your theory does sound plausible, although I think that most saws these days have essentially perfect arbors.
More than anything, I find that it will be a stubborn knot that starts the trouble with these blades. But for everyday typical cabinetmaking use, the thin blades work well.
post #5 of 20 (permalink) Old 05-01-2016, 09:06 AM
I used a thin rim Freud ripping blade for several years and the cut is not as smooth with them as with the glue line Freud I use now and that's on a unisaw so the arbor is good. I did find that using saw blade stabilizers improved the cut when I needed it and the stabilizers definitely improved chop saw cuts at 45* on hard woods.
timbertailor likes this.
post #6 of 20 (permalink) Old 05-01-2016, 09:33 AM
Don, when I hear about blade deflection the first thing that comes to mind is "Don't force it, let the tool make the cut." This is also true for other types of saw blades and router bits. You need to move just fast enough to prevent burning with a smooth and steady feed rate. This will give you the cleanest cut possible.
Vibration occurs when a tool is out of true. If you are getting vibration stop using the tool and find out why. A bent saw blade or router bit shank could be the cause; the cutter may not be properly tightened. Safety first!
I am currently using a Forrest Woodworker II thin kerf blade and have had no problems with it; the cuts are first rate. Forrest recommends using a stiffener with all table saw blades to improve the cut. I used the Forrest stiffener with a Guhdo-Gmaxx standard kerf blade and I believe the cut was smoother.
Name:	Guhdo GMAXX blade.jpg
post #7 of 20 (permalink) Old 05-01-2016, 12:58 PM Thread Starter
hawkeye10's Avatar
First Name: Don
That is a new brand of blades for me.
post #8 of 20 (permalink) Old 05-01-2016, 01:13 PM
PhilBa's Avatar
First Name: phil
I've used both but prefer the cut of the normal kerf blades. Though, I have a 3HP TS so don't have to worry much about bogging down.. I would use thin kerf if I was cutting a lot of thin pieces as it would yield 20% more (or take less wood to get the same amount).
If you are experiencing vibration, try a set of stabilizers.
Visit my shop website.
PhilBa is offline
post #9 of 20 (permalink) Old 05-01-2016, 05:37 PM
I must respectfully disagree. I've seen the comment made more than once that thin kerf blades will build up more heat, since they have less thermal mass. I have not seen any documentation to support that idea, and as a [retired] scientist, it makes no sense to me.
The amount of work required- and the amount of heat generated- is proportional to the amount of wood required; a blade with, say, half the kerf width will use half the power, and create half the heat of a full kerf blade. So, even if the mass of the thin blade is less (by half), the heat build up (temperature) will be the same in the two blades. In fact, since the total surface area of the two blades is virtually identical, with less mass- and less heat- the thin blade will theoretically dissipate heat faster than the thicker blade.
I'll get off my soapbox now!
jdonhowe is offline
post #10 of 20 (permalink) Old 05-01-2016, 07:46 PM Thread Starter
hawkeye10's Avatar
First Name: Don
John you make some points and they make since.
What saw blades do you like? Mike Tools and Woodworking 40 10-15-2015 11:06 PM
Bosch 4100 EQUINOX400 Tools and Woodworking 23 09-16-2014 02:39 PM
Availability Of 235mm Blades With 3.5mm kerf Gaia Tools and Woodworking 8 01-15-2013 05:25 AM
Forrestt II thin kerf blade Birch Tools and Woodworking 22 04-11-2009 12:59 PM
