JessEm Mast-R-Lift ll question - Router Forums
 5Likes
post #1 of 29 (permalink) Old 05-07-2016, 01:32 PM Thread Starter
First Name: Mateo
Default JessEm Mast-R-Lift ll question
I recently purchased a JessEm Mast-R-Lift 2 and I was surprised when I opened the box and the surface of the router plate seemed (to me) very different than any of the JessEm lifts I had seen online. I had spent a lot of time researching before buying and I had looked online at lots of images and as many videos as I could find. In every instance the router plate appeared to be smooth and black. Some images were not excellent, but many of them were well-lit and I could examine the plate quite closely. The plate on the router lift that was sent to me had a series of approx. 2" wide "stripes" running vertically across the surface of the plate. They were obviously formed by some kind of milling/buffing operation. I got in touch with JessEm and they assured me that all of the plates look this way. I went back and searched for ONE image that resembled mine, but I couldn't. I wasn't that concerned about the cosmetics of the plate, but the thing that seemed very strange to me was that if I ran a finger across the plate (and across the "stripes") it actually tracked kind of like a needle on a record and wanted to veer slightly every time it met a new stripe. Of course it was subtle, but it seemed very strange that the work surface of a power tool would have any effect at all on an object passing across it. If I lightly pushed a piece of wood lightly across the plate it would also tend to "wave" back and forth slightly according to the pattern. I am curious to what others think. Are their JessEm plates the same as mine? I realize that it might seem I'm being fussy or difficult, but I can't get over the fact that I can't seem to find a plate that looks like mine as hard as I try. Any thoughts/comments? thanks
matsyl is offline
post #2 of 29 (permalink) Old 05-07-2016, 02:11 PM
after a few uses that plate will look a whole lot different...
more like you have been using your tool...
you will clean and wax the plate before use and periodically there after I trust...
post #3 of 29 (permalink) Old 05-07-2016, 06:50 PM Thread Starter
First Name: Mateo
...I'm not so sure that the plate will be much different after use. The "buffing" marks I'm talking about are not on the surface. They are "baked in" to the plate. I don't think they will wear off, we'll see. As for cleaning and waxing the plate-in a way that's exactly why I thought it so strange that JessEm would sell a plate that had surface marks that can actually influence the travel (I admit, very superficially) of the workpiece. A lot of people put time, effort and $ into reducing friction on a work surface and the way JessEm machined this router plate they increased the friction!
matsyl is offline
post #4 of 29 (permalink) Old 05-07-2016, 10:17 PM
Those almost look like CenterLine scribes for centering the plate in the table.
Herb Stoops is offline
post #5 of 29 (permalink) Old 05-07-2016, 10:21 PM
wow!!!
post #6 of 29 (permalink) Old 05-07-2016, 10:39 PM
Return it. A brand new router plate should arrive absolutely flat and in perfect condition.. And, you will never quite trust the thing.
You might also consider getting a Triton TRA001 router, which has a built in lift and probably costs less than the lift you are unhappy with. I had a lift, but got rid of it and went with the Triton and a WoodPecker's aluminum plate, which is overpriced, but very nice because of its twist lock inserts, which can be ordered in any number of opening sizes. I don't know what you paid for the JessEm, but the Triton is about $289 on Amazon, and a Bench dog plate is about $45. The JessEm on Amazon is about $345.
The Triton TRA001 is a terrific table router so I retired my 1617 to hand held use. No regrets and I like how powerful it is. My thoughts on the matter at any rate.
post #7 of 29 (permalink) Old 05-07-2016, 11:13 PM
And I thank you Tom for the lift, I use it every day.
DesertRatTom likes this.
post #8 of 29 (permalink) Old 05-08-2016, 10:48 AM
rwl7532's Avatar
First Name: Ralph
@matsyl great pictures!
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #9 of 29 (permalink) Old 05-08-2016, 03:53 PM
PhilBa's Avatar
First Name: phil
I have a MRLII. It did not have those marks out of the box and does not have them now. You are paying premium $$ for that lift, expect perfect.
furboo likes this.
Visit my shop website.
PhilBa is online now
post #10 of 29 (permalink) Old 05-08-2016, 07:41 PM
furboo's Avatar
First Name: Rob
Same as Phil here, I also have the MRLII and it's very smooth. I can see the large bands you show in the first photo (I see more than 4 in the photo), but the surface is very smooth. Send it back.
Rob
furboo is offline
JessEm Master R Lift Excel Repair Model #02201 TRN_Diesel Tools and Woodworking 10 06-08-2018 12:48 AM
Mast R Lift II on an Incra Router Table Petellie Table-mounted Routing 1 11-07-2011 07:31 PM
jessem router lift gfc General Routing 0 08-06-2011 06:47 AM
Jessem RoutR Lift ??????????? hitnailonhead Table-mounted Routing 2 04-10-2008 10:30 AM
Jessem Rout-R LIft Papa's Workshop Table-mounted Routing 2 02-28-2008 02:59 PM
