Cyclone Collection Bag Hold-Down - Router Forums
 6Likes
  • 4 Post By Dejure
  • 2 Post By Dejure
post #1 of 4 (permalink) Old 05-15-2016, 08:00 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Default Cyclone Collection Bag Hold-Down
I picked up a box of clear lawn bags from a big box. Itís nice being able to just toss the bags, when full. However, I havenít been able to use them in my collector barrel for the cyclone, because of the common problem of the bag getting drawn up.
A week or so ago, I bought a roll of fencing with a pattern of, approximately, 2-1/2Ē x 5Ē openings. The plan was to make tomato plant cages, since the ones places sell are far too small for the size the plants grow here. I got all the cages done by measuring the diameter of the pots (e.g., cut off wine kegs) my sweetie was using, then making a circle with that diameter off the roll and cutting it there.
I cut in the middle of the wire of each rectangle. That left enough of the wire sticking out, on both sides or ends, to loop the wire over the wire of the end it was joined to, to hold the cages together.
I was looking at plywood, and my collection of PVC pipe, while mulling over the collection bag problem when it dawned on me I had about fifteen or so feet of fencing left. Using the same approach I used for the cages, I made a cage to insert in the collector barrel.
I had to cut about six inches off the top of the fencing to get it to fit the barrel. I left the cut wires about a half inch long on those too, so those could be looped back.
With all the cut wires looped back, there are no snags to catch on bags, or on your hand, if you have to dig around inside, like I had to today, to reclaim a couple tools the cyclone stole.
I fired up the jointer, then the planer and cleaned up a bunch of boards a friend dropped off the other day and the project, quickly, filled the bag about 2/3 full. The cage worked perfectly for holding the bags down and against the side.
Even with the bags installed, I was still able to see how full the barrel was through the view port too.
Because the metal wire is so thin, itís a snap wiggling the cage and pulling it out of the barrel. If you are careful, only the smallest bit of dust gets drug up, out of the bag.
The photos are, obviously, of the tomato plant cages. I was preoccupied with the project, so didnít get photos of the actual application, but I thought these might help for visualizing the solution.
Name:	Cyclone Bag Holder-1.jpg
Name:	Cyclone Bag Holder-2.jpg
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #2 of 4 (permalink) Old 05-15-2016, 09:22 PM
Originally Posted by Dejure View Post
I picked up a box of clear lawn bags from a big box. It’s nice being able to just toss the bags, when full. However, I haven’t been able to use them in my collector barrel for the cyclone, because of the common problem of the bag getting drawn up.
A week or so ago, I bought a roll of fencing with a pattern of, approximately, 2-1/2” x 5” openings. The plan was to make tomato plant cages, since the ones places sell are far too small for the size the plants grow here. I got all the cages done by measuring the diameter of the pots (e.g., cut off wine kegs) my sweetie was using, then making a circle with that diameter off the roll and cutting it there.
Because the metal wire is so thin, it’s a snap wiggling the cage and pulling it out of the barrel. If you are careful, only the smallest bit of dust gets drug up, out of the bag.
The photos are, obviously, of the tomato plant cages. I was preoccupied with the project, so didn’t get photos of the actual application, but I thought these might help for visualizing the solution.
I use a piece of old P-Lam I bend around inside the bag in the barrel, but your system sounds really good to me.. Good thinking,
Herb Stoops is online now
post #3 of 4 (permalink) Old 05-16-2016, 12:33 AM
A week or so ago, I bought a roll of fencing with a pattern of, approximately, 2-1/2Ē x 5Ē openings...I cut in the middle of the wire of each rectangle. That left enough of the wire sticking out, on both sides or ends, to loop the wire over the wire of the end it was joined to, to hold the cages together. Using the same approach I used for the cages, I made a cage to insert in the collector barrel.
I am going to do that this week. I have a fiber barrel that is very messy to empty, so I'm going to use some wire I have on hand to do this. Thanks for the suggestion. I won't get covered in sawdust every time I empty the barrel. Same with a second one in the garage where the jointer and planer play.
DesertRatTom is online now
post #4 of 4 (permalink) Old 05-18-2016, 12:41 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Just for reference, here are photos of the actual cage being used.
I pulled the cage and the wire is so thin no dust was apparent, on the floor, from the process.
Too, the bag filled nicely, since it couldn't be sucked up into the system.
On a final note, I made a new cage, which filled the entire barrel. It did make it MUCH easier to see through the bag and monitor the level of dust in the bag.
Name:	Cyclone Bag Holder-1.JPG
Name:	Cyclone Bag Holder-2.JPG
Name:	Cyclone Bag Holder-3.JPG
Name:	Cyclone Bag Holder-4.JPG
Name:	Cyclone Bag Holder-5.JPG
kp91 and honesttjohn like this.
Scraps are a myth.
Dejure is offline
Tips for Installing a Dust Collection System Router Forums Featured Topics 121 02-24-2017 12:20 PM
My current Dust Collection System Herb Stoops Tools and Woodworking 20 10-30-2015 06:11 PM
Dust Collection Bag for DC-610 Big Steve Shop Safety 0 02-20-2012 11:56 AM
