Mobile Carving Machine Base Pivots for Storage - Router Forums
 12Likes
  • 8 Post By Dejure
  • 2 Post By Cherryville Chuck
  • 2 Post By Dejure
post #1 of 7 (permalink) Old 05-23-2016, 02:19 AM Thread Starter
Dejure's Avatar
First Name: Kelly
Default Mobile Carving Machine Base Pivots for Storage
I bought this caver on a maple butcher block counter top, which weighed in at around one hundred pounds or so. Add the carver and a base and the entire thing weighed in around a couple hundred pounds. Obviously, it wasn’t very portable.
I wanted the unit to be portable, and to not take up a huge amount of space, when not in use. To that end, I made a box similar to what some would call a torsion box [then donated the butcher block to projects]. Once that was done, my plan was to make the table pivot using some swing set pipe I salvaged from a friends swing set (they were probably going to throw it out anyway).
The box works well. I made it large enough to allow me to install a sliding carriage and to install wider support rods.
Today, I some time out and built the portable base portion. It rolls easily and and pivots well. With about twenty more pounds on the top, it should be fairly counterbalanced. Even as it is, my wife can tip it.
In the upright position, it only takes up about fifty inches by about thirty inches. The table is about four feet by six feet.
It feels very stable, when dropping it down to the storage position.
I won’t do anything to adjust the balance yet, since I still have carriages and things to play with.
I had planned on adding telescoping legs at each corner, but, in use, it feels solid with just a single support at the center of each end.
I still have some detailing to do (e.g., cut the pipe to length), but, over all, I’m pretty happy with the results of today’s efforts.
Name:	Pivoting Bed-1.jpg
Name:	Pivoting Bed-4.jpg
Name:	Pivoting Bed-3.jpg
kp91, Gaffboat, TenGees and 5 others like this.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #2 of 7 (permalink) Old 05-23-2016, 02:25 AM
Rogerdodge's Avatar
First Name: Roger
That's clever ! Thanks for the share.
Rog
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
Rogerdodge is offline
post #3 of 7 (permalink) Old 05-23-2016, 05:41 AM
good thinking Kelly...
post #4 of 7 (permalink) Old 05-23-2016, 10:31 AM
Good idea Kelly. Now if you just move the drill press over and stack some of those odds and ends neater you'll have room for one more...Wait a minute. I think I posted that before. Kelly you and I have proven the maxim that no matter how much space you start out with you will over fill it in time.
Dejure and old coasty like this.
post #5 of 7 (permalink) Old 05-23-2016, 11:38 AM Thread Starter
Dejure's Avatar
First Name: Kelly
A few tricks to consider, regarding gaining room for more [of everything]:
1) Only buy equipment with horizontal surfaces;
2) Be willing to move odds and ends from horizontal surface to horizontal surface;
3) Be willing to stack things from one horizontal surface on things on another horizontal surface; and
4) . . .
Scraps are a myth.
Dejure is offline
post #6 of 7 (permalink) Old 05-23-2016, 12:10 PM
Nickp's Avatar
First Name: Nick
Great idea. Useful for other tool surfaces also...
Nick
Nickp is online now
post #7 of 7 (permalink) Old 05-24-2016, 11:48 AM Thread Starter
Dejure's Avatar
First Name: Kelly
An interesting point about the end product:
The individual legs were horrible to move around. It was like herding cats in a room full of dogs.
After I joined the two sides [with the rollers under them] and got the top installed on them, it rolls and maneuvers beautifully.
The extra weight actually helped the operating of the beast.
Scraps are a myth.
Dejure is offline
Intro and question john spies New Member Introductions 20 12-08-2018 12:08 PM
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
Hello DPugmire New Member Introductions 5 11-08-2010 07:29 AM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 08:54 PM
mobile base ? vegeta88 Tools and Woodworking 10 03-08-2008 10:10 PM
