What Is the Correct Name For Router Bit Bearing - Router Forums
 8Likes
post #1 of 22 (permalink) Old 05-25-2016, 03:24 PM Thread Starter
Contributor of the Month
Default What Is the Correct Name For Router Bit Bearing
I need to buy a large version of a router bit style bearing. What is the correct name? I see some with NR as part of the name. I need a bearing with a 1/2" ID (Inside Diameter) and a 1 1/8" OD (Outside Diameter).
I've done internet searches but don't know what the correct terminology is.
JIMMIEM is offline
post #2 of 22 (permalink) Old 05-25-2016, 03:42 PM
kp91's Avatar
First Name: Doug
Bearings | Rub Collars | Router Bit Bearings | Shaper Rub Collars
bearings and rub collars
Eagle has one PN 196-1800 for about $7.50
Mike and cocobolo1 like this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 22 (permalink) Old 05-25-2016, 05:26 PM Thread Starter
Thank You!!!!!
kp91 likes this.
JIMMIEM is offline
post #4 of 22 (permalink) Old 05-26-2016, 07:19 AM
Nickp's Avatar
First Name: Nick
All about bearings...see page 24 for your NR...if it is a suffix...
https://www.google.com/url?sa=t&sour...SBgdMPnTNQ89Eg
ISO 355 I think if you need some brain numbing...
cocobolo1 likes this.
Nick
Nickp is online now
post #5 of 22 (permalink) Old 05-26-2016, 07:48 AM Thread Starter
Thank You....that's some serious reading to do.
JIMMIEM is offline
post #6 of 22 (permalink) Old 05-26-2016, 08:29 AM
Nickp's Avatar
First Name: Nick
It's a lot easier to just take the number to any bearing supplier...standard numbering everywhere; cross-reference always available...unless you are engineering a specific application...
Nick
Nickp is online now
post #7 of 22 (permalink) Old 05-26-2016, 08:37 AM Thread Starter
Yes, it is for a specific application. I'm building a jig and the bearing is for the edge guide.
JIMMIEM is offline
post #8 of 22 (permalink) Old 05-26-2016, 08:50 AM
Nickp's Avatar
First Name: Nick
Then you don't need to worry about load, pressure or speed rating...just need no play and a good seal to keep the dust out... Not knowing what you're making, have you considered a "shoe" ? More surface area, less likely than a bearing to pick up a "nook or cranny"... just thinkin'...
Nick
Nickp is online now
post #9 of 22 (permalink) Old 05-26-2016, 08:59 AM Thread Starter
I have a set of plans that I'm following so I didn't give any thought to other options.
JIMMIEM is offline
post #10 of 22 (permalink) Old 05-26-2016, 09:09 AM
Nickp's Avatar
First Name: Nick
Whatc'ya makin'...or is it a surprise...
Nick
Nickp is online now
OMG, top bearing trim bit frustration vindaloo Router Bits - Types and Usage 4 08-15-2013 08:25 PM
Two bearing for Tongue and Grove bit? ppapineau Router Bits - Types and Usage 3 04-29-2011 12:11 PM
Router bit bearing David2058 Router Bits - Types and Usage 5 04-17-2011 02:32 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 10:20 PM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 10:03 PM
