Triton 3 inch belt sander clamped to bench on side - Router Forums
post #1 of 2 (permalink) Old 06-03-2016, 02:09 AM Thread Starter
First Name: Peter
Default Triton 3 inch belt sander clamped to bench on side
Hi
may I ask if any one has a Triton 3 inch belt sander with the clamps to clamp it upturned to the bench?
If so, have you ever tried to clamp it to a vertical surface so that the belt is vertical, something like the Festool Basis Plus bench belt sander.
Also, what is the performance of this sander like?
peteroo
Peteroo is offline
post #2 of 2 (permalink) Old 06-03-2016, 08:02 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Hi Peter
I have been using this sander clamped to the bench, for about 3 years now, but have not used it in the vertical position you described. About a year ago I used it free-hand, with the sanding frame attachment, to sand a large amount of very rough pine down to a reasonably smooth finish, but shortly after that the needle bearing seized. (The pine was really rough, and I was 400km away from my thicknesser, so I think I may have taxed it a little) Apart from that I really like this sander and continue using it clamped to my bench. I like the "stop" attachment when sanding square stuff.
Rob
Wildwood is offline
Problem with installing 1/2 inch bits in new Triton 2 1/4 router roofner General Routing 14 06-04-2013 02:54 AM
Drill 12 inch bench drill press 152.219110 kp91 Craftsman Manuals 0 03-22-2011 09:30 PM
PC 371 Compact Belt Sander $34 Tommyt654 The Bargain Bin 5 03-21-2011 10:13 AM
Harbor Freight Belt Sander Kelly Rittgers Tools and Woodworking 5 01-24-2011 02:01 PM
My Sander Arrived!... challagan Tools and Woodworking 9 04-26-2007 10:50 PM
