Need help - Router Forums
 27Likes
post #1 of 53 (permalink) Old 06-11-2016, 12:11 AM Thread Starter
roofner's Avatar
First Name: Gary
Default Need help
Here is a picture of a planter that I spied in my travels. I figured most out. Except the octagon wheels I know the angles are 22 1/2 degrees.
Not sure how to layout the cuts? Any suggestion appreciated.
jw2170, firstmuller and mikemikemi like this.
roofner is offline
post #2 of 53 (permalink) Old 06-11-2016, 12:31 AM
be over whelmed...
http://www.routerforums.com/tools-wo...lp-please.html
Nickp likes this.
post #3 of 53 (permalink) Old 06-11-2016, 12:34 AM
A wheel is much like a picture frame. All the angles have to be equal and all the sides have to be equal in length. If you can master those two requirements the pieces will mesh perfectly. Sounds easy doesn't it?
Nickp likes this.
post #4 of 53 (permalink) Old 06-11-2016, 12:42 AM
Semipro's Avatar
First Name: John_*
follow this link this how I do it
How to Draw an Octagon (with Pictures) - wikiHow
firstmuller likes this.
Semipro is offline
post #5 of 53 (permalink) Old 06-11-2016, 02:00 AM
Not so easy. I think my wife would love this. We have a space in the back yard where this would be really charming.
post #6 of 53 (permalink) Old 06-11-2016, 02:54 AM
Perfect for going up and down stairs!
DaninVan is online now
post #7 of 53 (permalink) Old 06-11-2016, 03:29 AM
have you forgotten what elevators are for...
post #8 of 53 (permalink) Old 06-11-2016, 09:01 AM
Garyk's Avatar
First Name: Gary
Laid out one for a game board a few years back. As per John's suggestion I googled "how to draw"and it worked out well. Bought a round cut board from Lowes which made it a bit more difficult.
Garyk is offline
post #9 of 53 (permalink) Old 06-11-2016, 09:26 AM
To get the desired angle for the wheel, divide 360 by the number of sides. I would most likely get as close as possible and wind up putting in a heavy duty spline, or tongue and groove the connecting points because warping, twists, splits, and other imperfections will make it pretty much impossible to get a perfect joint in construction grade lumber. By using splines, you could round out the wheels so the planter could roll around. Would have to have spokes of some sort to put the wheel on a shaft of steel pipe. Doesn't have to be a fancy construction to make it a movable planter. My wife likes to move stuff around in the garden and clever as this is, it will be heavy and awkward when filled with dirt and plants.
gacatron likes this.
post #10 of 53 (permalink) Old 06-11-2016, 11:45 AM
First Name: thomas
If not, then you'll have a mesh on your hands. (a groaner)
DaninVan and Nickp like this.
thomas1389 is offline
