Cross Slide Vise Drill clamp - Router Forums
 3Likes
post #1 of 12 (permalink) Old 06-15-2016, 01:27 PM Thread Starter
Country: United States Minor Outlying Islands
First Name: Keith
Default Cross Slide Vise Drill clamp
Not sure exactly what you call it, but see some on amazon, but none with good reviews. I have some that clamp but don't move in the x and y. Any recommendations on one that works well and is fairly precise? Thanks!
deathblosom is offline
post #2 of 12 (permalink) Old 06-15-2016, 01:46 PM
kp91's Avatar
First Name: Doug
we use Palmgren brand x-y vises and rotary tables at work, pretty decent products
https://www.amazon.com/Palmgren-CV80...6016258&sr=8-8
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 12 (permalink) Old 06-15-2016, 01:46 PM
cross slide it is..
Travers tool will have what you want accuracy..
Travers Tool Co. ? Find Metalworking Tools, Machine Tools & More
post #4 of 12 (permalink) Old 06-15-2016, 02:01 PM
Nickp's Avatar
First Name: Nick
Assuming you're putting this under a drill press, almost any of the slides will have some play in the threads forcing you to align in one direction...problem with end-play...
...unless you get up in the heavy duty commercial types...then you'll need another shop...
What're you doing with it ?...the application might drive different answers...metal? wood? big? small? intricate work?
If you're using it for drilling wood, any of them will work...just get the size that will fit in the press and will accommodate the size of wood...
I use a fence, clamps, stops, jigs, etc...for repeat work, especially when I need "precision". My x-y'er is sitting somewhere under something collecting dust (and rust, no doubt)...
DaninVan likes this.
Nick
Nickp is online now
post #5 of 12 (permalink) Old 06-15-2016, 02:31 PM
I bought a Chinese made and got what I paid for. Slop in the threads is correct but the one I have, and I assume most others are like it, works on dove tail guides which have a free play adjustment which helps. If possible also pick one that allows you to lock it in position once you have it where you want it. They are made for machining metal and like all other tools for machining metal you can go from quality levels where accuracy is wishful thinking to accuracy that will satisfy NASA. Prices vary accordingly.
post #6 of 12 (permalink) Old 06-15-2016, 02:45 PM
Gentleman...
you too Nick...
Doug hit the mark with his recommendation...
as in this one...
Cross Slide Vises
post #7 of 12 (permalink) Old 06-15-2016, 02:53 PM
MT Stringer's Avatar
I bought one from HF. Fairly cheep, and I got what I paid for.
I did manage to get it to hold my parts while I drilled them, but the material was aluminum so it drilled easy.
The prices seem to jump from under $50 to near $300. I would like to have the $300 model but it won't be today.
Good luck.
MT Stringer is offline
post #8 of 12 (permalink) Old 06-15-2016, 03:32 PM
Nickp's Avatar
First Name: Nick
Gentleman...
you too Nick...
Phew...glad you cleared that up...
DaninVan and Stick486 like this.
Nick
Nickp is online now
post #9 of 12 (permalink) Old 06-15-2016, 04:51 PM
That had to hurt! lol
DaninVan is offline
post #10 of 12 (permalink) Old 06-15-2016, 05:31 PM
Nickp's Avatar
First Name: Nick
...close one...
Nick
Nickp is online now
Rockler drill press milling vise reible Tools and Woodworking 15 01-10-2012 06:26 PM
base plate for mortising? How make it? help Bogydave Jigs and Fixtures 12 11-17-2008 02:15 PM
my old drill is showing its age ntreaster Tools and Woodworking 2 06-28-2008 12:57 PM
Drill safety AxlMyk Lobby 5 04-13-2007 08:27 PM
Drawer Pull Jig curiousgeorge Jigs and Fixtures 11 02-05-2007 10:44 AM
