Filter simplifies DC installation - Router Forums
 4Likes
post #1 of 15 (permalink) Old 06-23-2016, 11:04 AM Thread Starter
Default Filter simplifies DC installation
A few weeks ago, I bought two 2hp Harbor Freight dust collectors on sale (a steal at $187 each), and planned to use one in the garage, the other in a lean-to outside the shed that is my shop. Someone here suggested adding a Wynn filter to replace the cloth bag.
I called Mr. Wynn yesterday and he gave me a heads up, that their top of the line filter stops nearly 100 percent of fine dust from exiting the filter. So, I don't need to put up the lean-to. This is a really good thing because I don't have to do any construction, cut through walls, pass electrical outside, and it will keep cool air in during summer, warm in during winter.
I ordered the 35A274NANO Cartridge Kit which cost a little more than the HF unit. It filters to half a micron, blows clean with 60 psi air and has a metal jacket for ruggedness, and was even made to perfectly fit the HF unit and its clones. Website is http://wynnenv.com/.
Thought I'd share the info since I know a lot of you are as concerned about dust as I am.
DesertRatTom is online now
post #2 of 15 (permalink) Old 06-23-2016, 11:34 AM
why did you go so fine of a micron Tom???
after a couple of minuets of use a 2 micron filter cakes and behaves like a half micron..
remember to clean your filter after every few hours of use or your DC's efficiency will drop into the basement...
once the caking maxes out you be getting a lot of blow by...
post #3 of 15 (permalink) Old 06-23-2016, 09:14 PM
Oakwerks's Avatar
First Name: Kurt
I have that same filter on my 2hp ShopFox....
It moves a lot more air than the old bag filter...
Cleaning is simple with a blow gun....
I did make a simple manometer to monitor it...
Sorry the pic is sideways... Don't know why.....
Oakwerks is offline
post #4 of 15 (permalink) Old 06-23-2016, 10:25 PM Thread Starter
@Stick486 This filter has a couple of qualities, the fine filtration is just one. It is also very easily cleaned and passes almost zero fine particles back into the shop. I was going to set a coarser filter in a lean to behind the shop, but this makes it much simpler because I can keep it inside the shop.. Remember that I am a throat cancer survivor and really don't want to be inhaling the fine particles, for both cancer and clogged lungs.
And, I didn't have the information you posted. Thanks for the info on cleaning the filter frequently.
post #5 of 15 (permalink) Old 06-24-2016, 06:37 PM
Did you have any problems with the install Tom?
billyjim is offline
post #6 of 15 (permalink) Old 06-24-2016, 10:17 PM Thread Starter
Easy assembly. Bought some bolts and locknuts for the casters. Filter hasn't arrived yet, due in a couple of days. I'm going to do with the cloth bag for the garage unit since I can roll it outside.
post #7 of 15 (permalink) Old 06-25-2016, 07:44 AM
Oakwerks's Avatar
First Name: Kurt
I believe your installation will be the same as on my ShopFox ....
The filter comes with 3 clips, and takes only a few minutes to install..
billyjim and DesertRatTom like this.
Oakwerks is offline
post #8 of 15 (permalink) Old 06-26-2016, 03:53 PM Thread Starter
@Oakwerks Thanks for the info. I decided to try the thing out in the shop, but it sucked up some chunks and a plastic wrapper and lost suction. I guess I'm going to have to keep the old drum hooked up.
Have you found a source of replacement bags? I found some 60 gallon heavy duty bags that have an adequate opening, but will have to make a short platform for it to sit on to avoid it blowing off. I don't want to have to empty the bag, I just want to toss it out. HF doesn't seem to have the 70 stock gallon bags available.
post #9 of 15 (permalink) Old 06-26-2016, 06:26 PM
hawkeye10's Avatar
First Name: Don
I have the 1.5 HP Grizzly DC. Does this mean I need to knock the dust down in the top bag? I have been only doing that when I replace my lower bag.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 15 (permalink) Old 06-26-2016, 06:48 PM
when the cake resticts the exhaust and the DC's efficiency drops...
Small shop dust collection Barry747 Shop Safety 4 10-12-2015 12:04 PM
Do others do this (research)? > Dust Collection MAFoElffen Tools and Woodworking 61 08-27-2013 06:38 PM
Dust Collection in your shop Mark The Voting Booth 51 12-09-2012 11:07 PM
Air compressor water filter crquack Tools and Woodworking 33 05-29-2011 11:35 PM
Vacuum Filter Bags Mike The Bargain Bin 9 03-20-2009 12:03 PM
