I need help finding a tool - Router Forums
 5Likes
  • 1 Post By Shop guy
  • 3 Post By bryansong
  • 1 Post By Stick486
post #1 of 9 (permalink) Old 06-28-2016, 09:19 AM Thread Starter
bryansong's Avatar
First Name: bryan
Default I need help finding a tool
I'm not sure I can explain it well but it goes in your drill motor for drilling a hole in concrete for Tapcon screws then once the hole is drilled you simply slide the screwdriver adapter bit over the drill bit so you can use it to screw in the screw.
If that made any sense to you and you think you can point me in the right direction for purchasing one I'd appreciate it.
Bryan
bryansong is offline
post #2 of 9 (permalink) Old 06-28-2016, 09:25 AM
First Name: Richard
Bryan, I looked at Tapcon.com and the show an installation kit sold by Lowes, Home Depot and others that may fill your needs.
bryansong likes this.
Shop guy is offline
post #3 of 9 (permalink) Old 06-28-2016, 09:52 AM Thread Starter
bryansong's Avatar
First Name: bryan
Thank you Richard, that got me on track. I couldn't find it at Lowes and the one at Home Depot doesn't come with
a case but I did order one from Amazon. Condrive 500.
post #4 of 9 (permalink) Old 06-28-2016, 10:35 AM
boogalee's Avatar
First Name: Al
Bryan
If you want just the bit it is called a masonry bit.
Al B
boogalee is online now
post #5 of 9 (permalink) Old 06-28-2016, 11:21 AM
Nickp's Avatar
First Name: Nick
Milwaukee makes one for SDS-Plus rotary drill/hammer
https://www.reynoldsonline.com/ASSET...07497_Spec.pdf
Nick
Nickp is offline
post #6 of 9 (permalink) Old 06-28-2016, 11:44 AM Thread Starter
bryansong's Avatar
First Name: bryan
Thanks Nick.
The one I ordered has the adapter with a set screw so I can change out the drill bit and that's really more of what I want. That way I can take advantage of the drill bits that come with the package of Tapcon screws.
post #7 of 9 (permalink) Old 06-28-2016, 11:55 AM
Nickp's Avatar
First Name: Nick
Originally Posted by bryansong View Post
Thanks Nick.
...gotcha...
Nick
Nickp is offline
post #8 of 9 (permalink) Old 06-28-2016, 12:09 PM
Tommy Law's Avatar
First Name: Tommy
Send a message via MSN to Tommy Law Send a message via Yahoo to Tommy Law
There bit is nice bc it allows to not heep changing. For me I already had 5/16 nut drivers for drills and a 3/16" masonry bit for my sds drill was much cheaper than buying the fancy setup. I use a seperate impact for driving in tapconns anyway tend to have less strip out
Tommy Baltimore
"To alcohol...The cause of and answer to most of life's problems!" H. Simpson
Tommy Law is offline
post #9 of 9 (permalink) Old 06-28-2016, 03:51 PM
Bryan
it's called a ConDrive 1000...
use the Bosch drill bits...
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 04:33 PM
Chinese W1325ATC CNC - tool positioning semenov419 CNC Routing 2 01-29-2016 09:48 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 11:12 PM
Peak HP dgcutter General Routing 22 01-10-2013 09:23 PM
Selecting the Correct Router Bit LMT Onsrud (Onsrud) Router Bits - Types and Usage 1 02-08-2012 12:17 AM
