I need my maths checked - Router Forums
 2Likes
post #1 of 21 (permalink) Old 07-09-2016, 03:27 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default I need my maths checked
I have a dust deputy clone cyclone. its got 50 mm inlet and outlet. Thats not big enough for my 63mm ductwork.
so, if I multiply the 50 x 24% i get 62, yes?
Therefore, if i make my own larger cyclone and just multiply every measurement by 24%, it will end up in perfect scale, yes?
sunnybob is offline
post #2 of 21 (permalink) Old 07-09-2016, 06:30 AM
First Name: Earl
Sounds good. I just got a Dust Deputy a few days ago, and wrapped the inlet with enough painter's tape to get a good friction fit. Masking tape or duct tape should work too. It didn't take much tape at all--might be worth trying before building your own.
earl
greenacres2 is offline
post #3 of 21 (permalink) Old 07-09-2016, 06:37 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I've had mine for 18 months, its a brilliant device. I also used tape to pack the joints.
But I've improved all of my ductwork and now this is the smallest item in the line, causing a big restricyion of flow. To but the next size up is a stupid amount of money. So I'm going to make my own.
I've just worked out the size of the new improved one using 24% and I think I can go bigger again without losing anything.
So now I'm working on 50% larger.
sunnybob is offline
post #4 of 21 (permalink) Old 07-09-2016, 07:44 AM
Wood Chip's Avatar
First Name: Gary
I'm sure it's just a typo but I think you mean multiply every measurement by 124%, No?
Beyond that, I'm afraid I'll be of no help. I suspect there's an engineer in the group who can provide you with the right answer.
billyjim likes this.
Wood Chip is offline
post #5 of 21 (permalink) Old 07-09-2016, 07:46 AM
Just guessing, but wouldn't the size "ratio" be based on the relative cross-sectional area of the inlet/outlets?
tomp913 is offline
post #6 of 21 (permalink) Old 07-09-2016, 07:49 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
woodchip, yes, increase the size 24% over original. Now working on 50% larger. looks do able.
Tom, dont confuse me (its far too easy) i assumed by increasing all measurements the same percentage would keep the flow going.
sunnybob is offline
post #7 of 21 (permalink) Old 07-09-2016, 10:35 AM
chuckgray's Avatar
First Name: Chuck
This is true for the linear dimensions, but will not hold true for the area of the circular openings that are a square function.
chuckgray is offline
post #8 of 21 (permalink) Old 07-09-2016, 10:50 AM
If you are planning on building your own, you should consider making a Thien separator. They're a lot easier to build, and give equivalent or near equivalent performance to larger cyclones.
jdonhowe is offline
post #9 of 21 (permalink) Old 07-09-2016, 11:51 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I've looked closely at a thien. i have to admit i find it lacking. Every video I've watched says it needs tweeking and adjusting. And to be honest, That seperator looks a lot more complicated than a cyclone.
i'm happy with the vacuum power, got no desire to start all over again with motors and fan blades. My dust collection box seems O.K.
My only problem is I have a 50mm cyclone in the middle of a 63 piping system. Its an obvious restriction that I think I can improve on.
sunnybob is offline
post #10 of 21 (permalink) Old 07-09-2016, 11:55 AM
Before you go to all that trouble, have you actually tried a reducer to transition to the smaller Dust Deputy inlet/outlet?
Of course it won't be perfect, but how big is the inlet on your DC? (I'm guessing 63mm?)
DaninVan is online now
Checked On Shopsmith's Hollow Ground Blades... Jerry Bowen Tools and Woodworking 1 11-05-2012 02:05 PM
Some simple but interesting maths for tax-payers harrysin Lobby 6 07-01-2010 07:16 PM
Maths problems Al Robins Lobby 5 01-22-2010 07:29 AM
Help I can't get my head round the maths to make the jig OneDs Jigs and Fixtures 9 07-31-2009 02:00 PM
