Should I look at this CraigsList table saw? - Router Forums
 19Likes
post #1 of 23 (permalink) Old 07-21-2016, 10:38 AM Thread Starter
bryansong's Avatar
First Name: bryan
Default Should I look at this CraigsList table saw?
My son-in-law's birthday is coming up and I've been watching for a contractor saw on Craigslist and this cabinet saw showed up.
Grizzly table saw 1.5 HP tablesaw
It seems like it would be worth trying to repair it.
What do you think?
Bryan
bryansong is offline
post #2 of 23 (permalink) Old 07-21-2016, 10:59 AM
hawkeye10's Avatar
First Name: Don
The thing is you really don't know what is wrong with it and it could cost more to fix it than it's worth. It looks in pretty rough condition so maybe he hasn't taken care of it. If I didn't have to drive to far I might take a look. You can always find a deal but it's not easy and the waiting is a killer.
bryansong likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 23 (permalink) Old 07-21-2016, 11:23 AM Thread Starter
bryansong's Avatar
First Name: bryan
Don, those are my concerns also. I don't have a lot of time nor space right now to dedicate to working on it. I guess I'm just wanting
to make sure I'm not passing up on a good quality saw.
Thanks for your opinion.
Bryan
post #4 of 23 (permalink) Old 07-21-2016, 11:31 AM
There are a few different things it could be but the obvious and worst one is a burned out motor.
post #5 of 23 (permalink) Old 07-21-2016, 11:45 AM
kp91's Avatar
First Name: Doug
no, looks like a can of worms...
I am sure another will come along soon enough
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #6 of 23 (permalink) Old 07-21-2016, 11:49 AM
First Name: lee
Maybe you could meet at a motor shop. I would only buy it with the condition that the motor is fixable. If you have another motor then it might not apply. I have bought several old wood working power tools and I always try to buy one with a working motor. New motors are kind of expensive.
coxhaus is offline
post #7 of 23 (permalink) Old 07-21-2016, 12:39 PM
First Name: Richard
@Bryan : I would walk, no run away from that saw. Some Grizzly cabinet saws use an unusual starting process. Even though it may have a Lesson motor on it they will disavow any knowledge of it. The motor has the mounting brackets built into the motor housing and you must buy a motor from Grizzly to replace it. All of the above was learned the hard way. My saw was just out of warranty when I had a similar no start situation. Grizzly did take care of me on it but they could have said "sorry, Richard." As I said I would run from it. I also would be willing to bet he knows it is not a wiring problem.
jj777746 and bryansong like this.
Shop guy is offline
post #8 of 23 (permalink) Old 07-21-2016, 12:47 PM Thread Starter
bryansong's Avatar
First Name: bryan
I'm running Richard, I'll keep looking.
Thanks to all of you.
post #9 of 23 (permalink) Old 07-21-2016, 12:59 PM
Guest
That's the safest course of action, Bryan, but if you'd like to do some further investigating here is a suggestion:
If the motor hums when switched on but does not turn, it could be something as simple as a bad starting capacitor. They are typically not very expensive if contained in a housing external to the motor body. If it does not hum, it could be anything from a broken wire to a bad switch to a burnt-out motor. That may or may not be expensive but it's risky if you don't know something about motors and electricity.
jj777746 likes this.
163481 is offline
post #10 of 23 (permalink) Old 07-21-2016, 01:13 PM
agreed....
Adjustable Height Workstation/Router Table and more MT Stringer Show N' Tell 84 01-22-2018 10:50 PM
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Converting a Bosch RA1180 to a table LagunaPaul Table-mounted Routing 31 08-11-2014 10:45 PM
I also need a router table. JohnnyB60 Table-mounted Routing 27 02-25-2012 09:24 PM
Your wisdom is sought gcodom Table-mounted Routing 8 12-10-2010 08:03 AM
