TS sled; Yes or No? - Router Forums
 7Likes
post #1 of 23 (permalink) Old 08-01-2016, 08:16 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default TS sled; Yes or No?
I am trying to make up my mind about a TS sled. I had one with my last TS and had mixed feelings about it. I would just like to find out what y'all think about them.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 23 (permalink) Old 08-01-2016, 08:32 PM
JOAT's Avatar
First Name: Theo
Table saw sleds are great, more than worth the time to make them. I always make mine with a bridge over the blade, so there is no way I could get my hand in the blade, unless I actually tried. Get 'em set up and they're dead on, and stay dead on. By the way, I like table saw sleds, a lot.
neville9999 likes this.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #3 of 23 (permalink) Old 08-01-2016, 08:45 PM
First Name: Richard
Plus 1 what Theo said. I resisted building one for years then one day I said to myself "self you might be missing out on a good thing because of your hardheadedness" (which by the way I well known for). So I built one and have loved it a lot. Use it all the time ever since the first day. My advice is not to build it to large or to small. Only you can decide the size. Mine is 16" front to back and for me just right. My shop is small so it fits my purposes just right. Did I say I like sleds? Well, I do and wish I had made one lots sooner.
Shop guy is offline
post #4 of 23 (permalink) Old 08-01-2016, 08:47 PM
Nickp's Avatar
First Name: Nick
Yup, mixed here too...when the pieces are small the miter works...when they're bigger the SCMS comes out.
And then there's those times when you can't do without it. You cant beat the repeatability...especially when stops get involved...
Sort of like a torque wrench...when you need it nothing else will work.
I have big and small for each of my saws...
Nick
Nickp is online now
post #5 of 23 (permalink) Old 08-01-2016, 09:05 PM
BrianS's Avatar
First Name: Brian
I can't add much to what has been said. I have one, and would not be without it. It's SO nice to know you are making a straight cut. With my mitre guide, I could never be sure without dragging the square out and checking it.
As Richard said, 16" will probably do you for most things. But, make a panel sled as well, for those times your crosscut sled isn't big enough.
Brian
(Origin uncertain)
BrianS is offline
post #6 of 23 (permalink) Old 08-01-2016, 09:11 PM
First Name: Ken
Theo, would you be so kind as to post a picture of your sled? I'd like to see how you did the bridge. Is it just a strip of wood?
kklowell is offline
post #7 of 23 (permalink) Old 08-01-2016, 09:33 PM
First Name: Clay
Definitely a good shop helper. Very safe and accurate, you will probably want more than one.
fire65 is offline
post #8 of 23 (permalink) Old 08-01-2016, 10:23 PM
mixed also but they sure can make life easy and save the day at times...
Ray Newman and JFPNCM like this.
"SNORK Mountain Congressional Library and Taxidermy
post #9 of 23 (permalink) Old 08-01-2016, 11:52 PM
JOAT's Avatar
First Name: Theo
Well, would if I had a picture. And cut my last one apart to use the parts on something else. Haven't made another yet, because need to adjust my saw first, and too busy on other things just now to get to it.
Pretty simple tho. My sleds usually have a piece of 2X4 on each end, on their side. I rarely cut anything anymore that's over 1/2 or 3/4" thick. So I run a piece of 2X4 front to back, about 7/8 to 1" off the sled. With that piece of 2X4 that low, pretty much would have to stick my fingers under it to get to the blade. Also, on the back end of the sled, once the saw cuts whatever, I have a stop on the sled, so it cannot go far enough forward for the blade to cut thru the back and be visible - read out in the open where I could put my hand on it. Plus, I have sort of a hand stop on the back piece of 2X4 and put it all together so I almost have to have my hand there, and safe, before I can use the sled - makes it too awkward to use otherwise. I'm a big fan of personal safety in the shop. Hehehe That's the best description you'll get, because when I make the next sled it'll be along those general lines, but I have not a clue just how it will actually turn out. I try to upgrade each time, so never any two the same. Next time I'll try to take some pictures. Won't be pretty pictures tho, I don't go much for pretty with my shop tools, just want them functional, and safe.
JOAT is offline
post #10 of 23 (permalink) Old 08-02-2016, 12:37 AM
vindaloo's Avatar
First Name: Angie
This is how I did the bridge on mine, but a strip of wood might do. I used plastic so I could see where I was cutting.
firstmuller likes this.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
Save-Your-Time Saw Sled NickyP Show N' Tell 34 11-17-2015 04:43 PM
Combining The Incra LS Positoning Systeprem To The Express Sled Jerry Bowen Tools and Woodworking 8 03-11-2014 06:39 AM
coping sled advice dickhob Table-mounted Routing 2 05-18-2012 11:18 AM
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 11:14 AM
Table saw sled.......... Duane867 Tools and Woodworking 5 07-29-2009 08:59 PM
