Problems with a DW 716 chop saW - Router Forums
post #1 of 9 (permalink) Old 08-08-2016, 08:39 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Default Problems with a DW 716 chop saW
I bought the DW716 new in late 2013 and within a year it began leaking oil around the blade housing on the right side. This was an in warranty repair at the DW shop and the saw continued to perform very satisfactorily. That brings me to today, 2 years later, when I noticed the same area was once again coated with oily sawdust. Fortunately, this time it was not leaking enough to stain any wood but the dust build up was obvious. So, it's back in the shop today.
My question, has anyone on the forum had any similar problems with a DW716 or am I one of the unfortunates here?
Jon
JFPNCM is online now
post #2 of 9 (permalink) Old 08-09-2016, 07:32 AM
how much do you use the saw..
post #3 of 9 (permalink) Old 08-09-2016, 11:50 AM Thread Starter
JFPNCM's Avatar
First Name: Jon
It's used intermittently based on the project and may sit idle for a week at a time. The heaviest use was on the turtle project and that was on KD fir so not really taxing cuts. No compound cuts have been made.
The main use is to cut pieces (maple, oak, cherry, walnut etc) to proximal length which are then finished on the TS.
The blade is sharp, clean and true to the table.
Jon
post #4 of 9 (permalink) Old 08-09-2016, 12:40 PM
let's dig a bit...
what blade (specifically) are you using and what size...
post #5 of 9 (permalink) Old 08-09-2016, 01:07 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
A 12" 80 tooth DW blade. I swapped the original blade out the day I bought it.
Jon
post #6 of 9 (permalink) Old 08-09-2016, 02:00 PM
what is the grind...
blade ID...
post #7 of 9 (permalink) Old 08-09-2016, 04:30 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
It's an old model that is no longer available but as I recall it's an 80 tooth fine cross cut blade, carbide tipped.
When I dropped off the saw I asked the DW shop if they thought the blade might be contributing to the problem and their response was "highly unlikely".
Jon
post #8 of 9 (permalink) Old 08-09-2016, 04:31 PM
okay...
post #9 of 9 (permalink) Old 08-09-2016, 10:08 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Appreciate the discussion. i'll post the end result, hopefully in 3-4 weeks as that's their backlog on repairs.
Jon
Problems, Problems, Problems..... Frankj3 Sign Making 9 07-04-2016 10:21 PM
Computer problems routerbitron New Member Introductions 1 01-24-2013 10:08 PM
First table style routing gave infeed and outfeed problems loninappleton Table-mounted Routing 3 09-20-2009 06:48 PM
Problems, problems, problems nikki1492 General Routing 7 07-21-2009 09:50 AM
