How long have you been using a Router? - Page 5 - Router Forums
View Poll Results: How long have you been using a Router?
Less then 1 year 69 18.25%
1 to 2 years 30 7.94%
2 to 5 years 55 14.55%
5 to 10 years 47 12.43%
10 to 20 years 62 16.40%
More then 20 years 115 30.42%
Voters: 378. You may not vote on this poll
post #41 of 50 (permalink) Old 04-10-2011, 02:31 AM
On vacation
First Name: Rixon
I am new here I just recently across your forum, really nice forum,it is honor to join your community,please cope-rate with me.
thanks
Rixon is offline
post #42 of 50 (permalink) Old 04-11-2011, 08:03 PM
pal
pal's Avatar
First Name: Harold
I bought my first router a Bosch pof 50 in 1982 and it is still going strong. It only takes 1/4" bits.It has an eltronic switch that play's up occasionaly just have to give it a light bump on the side with the heel of the hand and it works again.
Harold
pal is offline
post #43 of 50 (permalink) Old 05-02-2011, 02:01 PM
Country: Belgium
First Name: Jean-Marc
Default Which Router would you choose
I went to a tools shop today for buying a router, but hesitate to take the decision. I thought the best to do is to ask advice to the experts on this forum.
I have a Ryobi R152, 750 watt since 1998. I saw a Bosch 1400watt / 8mm thickness for the shaft fixing and a Black & Decker 1600watt and up to 12mm shaft, it look bigger and stronger. Which must I buy. I will keep the Ryobi for freehand routing and is willing to buy a router, with which I can do heavy jobs, and also be able to fixe it on a table. The Black&Decker seems ok. What do you think? Thanks in advance
Name:	blanck&decker 1600 watt.jpg
Name:	Bosch 1400watt.jpg
Jean-Marc is offline
post #44 of 50 (permalink) Old 05-02-2011, 03:32 PM
DAMIR66's Avatar
Country: Croatia
First Name: N/aDAMIR
Last year I decide bought a new router and chosen B&D 1600 W.I bring home and when clamping on the table the body of the router is swing left-right on his guide about 2-3 mm.I return router same day and get money back.When I ask in service about this problem they said "i`s normaly for this money" wtf?All comments is to much.
DAMIR66 is offline
post #45 of 50 (permalink) Old 05-02-2011, 04:46 PM
First Name: Sam
Default Off & On
I have used my router off and on for over 20 years. I have a Sears 315.17491. 1 1/2HP. Its old and loud, but it works. This year I made a table for it. Who says you can't teach an old dog new tricks.
woodinhead is offline
post #46 of 50 (permalink) Old 05-02-2011, 04:54 PM
Hi Sam
Of all the bad things a router can do to you ,wiping out your hearing is the worse, I now say WHAT a lot now days because I didn't wear ear plugs for 40 years or so..
The higher the speed the higher the DB will be.
post #47 of 50 (permalink) Old 05-02-2011, 05:43 PM
HI Jean-Marc
I would suggest you keep looking ,,and pass on both of them, they both have a real down fall,,the Small hole in the base.
post #48 of 50 (permalink) Old 05-03-2011, 02:04 AM
gav
Country: Croatia
First Name: Gavin
I have that Bosch router, actually the earlier 1300 watt version. For the price, it's a pretty good router. It has all the features that a high end router has, just less power.
After lock fine height adjust, built in lights, soft start and constant speed control, variable speed, and a 6 step depth stop.
I have yet to use a bit that doesn't fit through the base hole, and in fact I doubt there is an 8mm bit that is too big for it. It's not like you would consider using to make raised panel doors.
gav is offline
post #49 of 50 (permalink) Old 01-18-2012, 05:27 PM
First Name: N/A
I'm 53 and been using a router since I was 15 in my dad's shop. Routers and accessorries have come a long way!!!
Pine Cone is offline
post #50 of 50 (permalink) Old 01-18-2012, 05:50 PM
Since I was in my teens. Now in my upper 40's.
Whittier, CA.
Have a nice & safe day!
jlord is offline
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
router bit too long jeffcabin Starting Off 5 09-15-2008 04:28 PM
