Attaching Patterns To Wood - Router Forums
post #1 of 5 (permalink) Old 05-25-2010, 08:51 AM Thread Starter
Vector01's Avatar
First Name: Frank
Default Attaching Patterns To Wood
Hi All:
Here's a tip for the new scrollers out there. When attaching you pattern, first use clear packing or blue painters tape on the wood. Make sure you don't overlap the layers of tape. This will ensure your pattern will lay flat on the wood. Then apply your adhesive to the back of the pattern. I've been using Elmers Craft Bond multi-purpose adhesive for a few years now with great results. After spraying your pattern, let it sit about a minute so it gets tacky. Apply your pattern and cut away. When you are finished cutting, you can just peel the tape off with the pattern.
If your making puzzles and you want a permanent bond, spray the wood and the back of the pattern (no tape). Immediately apply the pattern to the wood. Smooth it out and you will have a permanent bond. If you want a protective finish on your puzzle, let the adhesive sit for about an hour (to set). Apply two light coats of either puzzle saver or Modge Podge. Wait for the first coat to dry before applying the second coat. This is a water based product and could lift the pattern from the wood. Once dried you can cut your puzzle.
Vector01 is offline
post #2 of 5 (permalink) Old 05-25-2010, 10:10 AM
Gene Howe's Avatar
First Name: Gene
Thank you for both of your posts.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 5 (permalink) Old 05-25-2010, 01:46 PM
CanuckGal's Avatar
First Name: Deb
Good info Frank! Thanks for posting.
I measured, I marked, I cut.
CanuckGal is offline
post #4 of 5 (permalink) Old 11-23-2010, 10:43 PM
LMan's Avatar
First Name: Lou
I use 3M super 77 Multipurpose Adhesive and give your pattern a lite spray let it tacky and stick it on, don't spray it on the lumber or it will be hard to remove. This is fast and cheaper a can of spray adhesive will last a long time, Lock tite makes a good adhesive as well.
LMan is offline
post #5 of 5 (permalink) Old 10-18-2011, 02:50 AM
First Name: Spence
I like that 'puzzle saver' or 'modge podge' tip for puzzles... thanks for posting it.
Spence
SawTooth1953 is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 01:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Attaching Patterns jd99 Tools and Woodworking 5 12-23-2009 08:33 AM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 08:40 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 06:58 PM
