Mobile Base/Wheels for DW 788? - Router Forums
post #1 of 13 (permalink) Old 06-15-2010, 07:25 PM Thread Starter
First Name: Steve
Default Mobile Base/Wheels for DW 788?
Need to know where I can order some canister wheels/mobile base for the DeWalt DW788 scroll saw that I just put together? I found one listed for $179.99 but am not sure if it will work with this triangular base. I need to be able to move this unit around when necessary. What are all of you guys using on this stand? Thanks for any input.........
Steve
WoodHaven is offline
post #2 of 13 (permalink) Old 06-16-2010, 05:41 AM
dutchman 46's Avatar
First Name: Howard
Good Morning Steve. Check out Harbor freight. I have a couple, and You need to add the wood, and set it up. Seems to work well.
John 3:16
dutchman 46 is offline
post #3 of 13 (permalink) Old 06-16-2010, 07:37 AM Thread Starter
First Name: Steve
Hi Howard: Do you have a link to their site & exactly what you are using? How did you set your's up?? Thanks............
Steve
post #4 of 13 (permalink) Old 06-21-2010, 07:02 AM
First Name: Howard
Steve
Steve, I have been through the Harbor Freight site, and magazine, and I don't see them. The web site is; Harbor Freight Tools . They have a good supply of casters on sale, for Father's day. but the catalog is good for a while yet. You can call 1-800-423-2567 and ask about the carts. Hope this helps. You can stop by Home Depot, They had some also. i HOPE THIS HELPS. Here is another that I was looking for. http://woodgears.ca/mobile_base/jointer.html It has a video to help show what this fella does.
John 3:16
post #5 of 13 (permalink) Old 06-21-2010, 08:41 AM Thread Starter
First Name: Steve
Thanks! However, I found one at Amazon that is specifically made for the DeWalt 788 unit. It sells for around $143.00 & as far as I am concerned is well worth the investment! Here is the link for anyone interested:
Amazon.com: HTC HRS-2158 3 Leg Scroll Saw Stand Mobile Base: Home Improvement
Steve
post #6 of 13 (permalink) Old 06-23-2010, 09:36 AM Thread Starter
First Name: Steve
Reply #9 on: June 22, 2010, 10:10:08 PM Quote Modify Remove
UPDATE! I received the mobile base unit yesterday. Took 15 min to attach the wheels to the base. Lifted the scroll saw/base onto the unit & it works perfectly for my needs. Some of us really need to be able to move the saw around & this seems like a good solution. Locking the front two wheels in place does not allow the unit to move whatsoever & I was able to use the saw without any problem. Oh, & it did only lift the saw 7/8" off the ground which is no big deal. The only thing that I am going to do & would suggest to others is to order a second "Floor Lock Kit" (FLK) to use on the other side of the base. This is because when you only use the one that is located on one side there is some wobble to the unit when you lock it down. That's why I only locked the two front wheels when I used the saw. With the additional FLK located on the other side you can lock both of them down in order to elevate the central larger wheel off of the floor. This way the triangular base will be very stable as it will be supported on both sides. I hope that I am making some sense here? I think that with the square type bases this would not present the same problem using only one FLK mechanism. If one also wanted to they could drill holes through the mobile base in order to bolt down the saw base. This would really stabilize the unit onto the base & I may wind up doing that; although, it's working fine for me the way it is. Anyway, if one needs the saw to be able to be moved around, you can't go wrong with this mobile base.
Steve
post #7 of 13 (permalink) Old 06-24-2010, 08:24 PM Thread Starter
First Name: Steve
Another update: Well, I attached the scroll base to the mobile base unit today. It was simply a matter of positioning the unit, using a scribe to trace around the scroll base holes, drilling three 1/2" holes, and using 3/8" bolts to secure it. Worked out really nice & now I don't have to worry about the scroll moving when I use the wheels on the mobile base to move the unit around. Now when I receive the other floor locking mechanism, the set up will be absolutely perfect!!
Steve
post #8 of 13 (permalink) Old 07-22-2010, 07:49 PM Thread Starter
First Name: Steve
Got the additional floor locking mechanism & placed it on the opposite side of the base unit. Adjusted both units so that the base does not move at all now! It's a very nice set up overall. I can now lock the scroll saw in place & move it whenever I need to with no hassel whatsoever. Sorry about not being able to take & post pictures of the unit.
And YES, I would recommend this to a friend!
Steve
post #9 of 13 (permalink) Old 03-01-2012, 11:43 AM
Big Steve's Avatar
First Name: Steve
Steve, your last post was about 6 or 7 months ago. Still happy with the DW? I have an old Delta 16" and I want to upgrade.
Suggestions anyone?
Steve
Richmond, Virginia
Big Steve is offline
post #10 of 13 (permalink) Old 03-05-2012, 08:23 AM Thread Starter
First Name: Steve
Hi Steve: To be honest, I haven't used the machine much. However, whenever I do get to use it I have no problems. The DW operates fine for what it's designed to do. Depending on your needs, you may also want to look around at other scroll saws just for comparison sake. I believe that the prices have come down to affordable levels for most of these machines. Good luck in whichever model you choose!
Steve
New to the forum; mobile router center questions caustill General Routing 5 01-31-2010 11:22 PM
Getting mobile xplorx4 Show N' Tell 13 08-22-2009 05:22 PM
Mobile Bases AVman Tools and Woodworking 14 02-27-2009 04:07 PM
