temp glue? - Router Forums
post #1 of 23 (permalink) Old 08-20-2010, 06:49 AM Thread Starter
Default temp glue?
I need a glue to affix my patterns to the work piece for the scroll saw band saw ect,
after cutting i can peel the pattern off! dose anyone know what i am looking for and where to purchase it. Thanks Bill.
stonestacker is offline
post #2 of 23 (permalink) Old 08-20-2010, 07:13 AM
Country: Germany
First Name: Titus
Double sided carpet tape is the best.
Titus A Duxass is offline
post #3 of 23 (permalink) Old 08-20-2010, 07:38 AM
kp91's Avatar
First Name: Doug
I use Krylon easy tack repositionable spray adhesive, here's a few comments from people more experienced than me...
elmers spay adhsive
If you can't get your pattern off, try a little heat, mineral spirits, and work very slowly from one edge.
Michaels or some other craft store will probably be your best bet for finding it.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 23 (permalink) Old 08-20-2010, 07:39 AM
Hi Bill - I don't do scroll work myself but a friend of mine is quite accomplished at it and he uses Elmers spray craft adhesive. Available at Walmart in the craft and fabric department. I've used it myself for bandsaw work once in awhile and it will leave a bit of residue but it comes off easily with mineral spirits or alcohol.
Good luck
John Schaben
jschaben is offline
post #5 of 23 (permalink) Old 08-21-2010, 06:30 PM
scrollwolf's Avatar
First Name: Jack
I have used both the Elmers spray and I have also used their glue sticks. I apply it to the pattern and not the wood.
Jack
"If it ain't broke, don't fix it, give it to me!"
scrollwolf is offline
post #6 of 23 (permalink) Old 08-21-2010, 07:11 PM
HI Guys
I use BLAIR ARTIST MNTG ADHSV 11 oz, it's made just for that job..
Amazon.com: BLAIR ARTIST MNTG ADHSV 11 oz: Home Improvement
post #7 of 23 (permalink) Old 08-21-2010, 11:40 PM
CanuckGal's Avatar
First Name: Deb
The spouse has been using 3M 77 adhesive.
I measured, I marked, I cut.
CanuckGal is offline
post #8 of 23 (permalink) Old 08-22-2010, 06:43 AM
allthunbs's Avatar
First Name: Ron
Hi Bill:
The use of glues for bandsaw and scroll saws and that used with a router have different requirements. Routers need to hold a pattern fast and not allow it to move even under side stresses. I would agree with the suggestions above for the router.
Bandsaw and scroll saws don't stress a "pattern" when it is made of paper but the paper is a devil to remove. In the typesetting industry they use a hot wax that is dry strip able to glue up galleys. A good drafting or artist supply store should be able to help. Don't bother with the heater, use a fine-groove tile float and a candle. Heat the float with the candle and run the wax across it and apply like you would tile mastic. It will darken the wax but save you a bunch of bucks.
Hope this helps.
Allthunbs
allthunbs is offline
post #9 of 23 (permalink) Old 11-23-2010, 09:49 PM
LMan's Avatar
First Name: Lou
3M 77 adhesive you won't go wrong.
LMan is offline
post #10 of 23 (permalink) Old 02-13-2011, 07:54 PM
wooden_grandma's Avatar
First Name: Tammy
I know this is an old thread, but I use rubber cement. Rubber cement provides the bond that you need and the pattern easily detaches later. Any residue left over easily rubs away with very little effort.
wooden_grandma is offline
Hello stephan New Member Introductions 7 10-17-2011 01:40 PM
Hot melt glue to hold small parts for pattern routing? rstermer Portable Routing 22 06-22-2009 09:05 PM
Wanted: Looking for glue pot bobj3 Woodworking Classifieds 16 03-30-2009 07:46 AM
Biscuit or glue joint Ghidrah Router Bits - Types and Usage 13 11-13-2008 04:10 PM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 10:18 AM
