New To Scrolling - Page 2 - Router Forums
post #11 of 22 (permalink) Old 10-25-2010, 08:42 PM Thread Starter
FloridaTermite's Avatar
First Name: Kristofer
Originally Posted by del schisler View Post
first thing get good blade's here is the link Mike's Workshop selling Flying Dutchman brand fret and scrollsaw blades Also when you start . If you don't know why the saw doesn't saw streight ? The blades are punch out and have blade set only on one side. That is the reason so don't think their is simething wrong with the saw. FYI good luck I use a 18" hagner scroll saw here
Thanks Del! If I get this thing running smooth I will get some of those blades...
bobj3: I'll see what I can do. Do you know a good place to find key stock?
~Kristofer
FloridaTermite is offline
post #12 of 22 (permalink) Old 10-25-2010, 09:35 PM
HI
ACE hardware/HD/Lowes,, ACE has just about any size you need,,,it looks like 3/16" or 1/4" will do it, it comes in 12" sticks the norm.
post #13 of 22 (permalink) Old 10-26-2010, 12:12 AM
CanuckGal's Avatar
First Name: Deb
Nice job on the restoration!
I measured, I marked, I cut.
CanuckGal is offline
post #14 of 22 (permalink) Old 11-23-2010, 09:34 PM
LMan's Avatar
First Name: Lou
Mike sells good blades that is where I get all of mine.
LMan is offline
post #15 of 22 (permalink) Old 11-23-2010, 10:21 PM
HI Lou
I use mike's blades also but here's a little tip if you pickup some pin type scroll coping hand saw blades and cut the pins off they work great in the scroll saw and they say sharper and will last longer cutting plywood,hardwood,etc. hand type blades are thicker and are made for hvy duty work the norm..when you pickup some pickup some metal cutting blades also and do the same thing cut off the pins..that way you can cut Alum. and light steel with your scroll saw..
you will be amazed how easy it is to cut a strait line with the coping saw blades install on your scroll saw ,almost like a band saw..
http://www.amazon.com/s/ref=nb_sb_no...blades&x=0&y=0
http://www.amazon.com/2014500-Coping...0572619&sr=1-7
post #16 of 22 (permalink) Old 11-24-2010, 10:03 AM
LMan's Avatar
First Name: Lou
Hi Bj thank you for the tip I will have to try that out.
LMan is offline
post #17 of 22 (permalink) Old 11-26-2010, 06:58 AM
First Name: del
those will have teeth set on both side's of the blade. i belive . Like was said they will cut in a streight line with having to keep pushing the wood to get it to go streight.
del schisler
port st. lucie, florida
del schisler is offline
post #18 of 22 (permalink) Old 12-16-2010, 01:09 PM Thread Starter
Thanks for all the replies! This month has been very busy and I have not been able to do much with the scroll saw. I have been able to get it running, and it works great! I will post some pictures of the completed saw as soon as I can. Thanks again for all your input! BTW I found a really cool scroll saw pattern for xmas reindeer using a scroll saw. I thought you all might like it!
Carving a 3D reindeer ornament on the scrollsaw
~Kristofer
post #19 of 22 (permalink) Old 12-16-2010, 02:51 PM
Thanks Kristofer
That's neat :, just in time for Xmax..
post #20 of 22 (permalink) Old 12-16-2010, 03:02 PM
Bob N's Avatar
First Name: Bob
Thanks for the link Kristofer! Those look really cool to make.
Bob N is offline
Scrolling Bob N Wood Scrolling 31 04-18-2012 01:07 PM
What is wood scrolling? do you have a picture of the tool? popeyebedford Wood Scrolling 6 07-13-2007 05:02 PM
Scrolling Milt Starting Off 5 02-12-2007 03:59 PM
Tips and Tricks for Scrolling whitewolf710 Wood Scrolling 3 08-29-2006 12:40 AM
