New To Scrolling - Router Forums
post #1 of 22 (permalink) Old 10-22-2010, 05:33 PM Thread Starter
FloridaTermite's Avatar
First Name: Kristofer
Talking New To Scrolling
Hello all! I just found an old Atlas 24" Jig/Scroll Saw on Cr*igslist for $50...it's heavy!
I hope to have it painted up and running in the next week or so.
I thought I would ask and see if any of you are using old iron like this?
Have any of you had one such as this in the past and have since "upgraded" for one or more reasons?
Any info you have would be appreciated.
I'm excited to get into scrolling
One very similar to mine can be viewed at:
OWWM - Atlas Press Co. Serial Number Registry - Jig/Scroll Saw No. 000807
Best Regards,
~Kristofer
FloridaTermite is offline
post #2 of 22 (permalink) Old 10-23-2010, 12:47 AM
xplorx4's Avatar
First Name: Jerry
I have an old 24" Delta with the spring head good old machine, made in the USA. I plan to clean it up, make a new strand and use it. It was given to me earlier this year by a friend.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 22 (permalink) Old 10-23-2010, 04:40 AM
First Name: del
first thing get good blade's here is the link Mike's Workshop selling Flying Dutchman brand fret and scrollsaw blades Also when you start . If you don't know why the saw doesn't saw streight ? The blades are punch out and have blade set only on one side. That is the reason so don't think their is simething wrong with the saw. FYI good luck I use a 18" hagner scroll saw here
del schisler
port st. lucie, florida
del schisler is offline
post #4 of 22 (permalink) Old 10-23-2010, 11:18 PM
First Name: Paul
I got an old solid cast iron Foley-belsaw it weighs a ton but it is awesome still have to add oil to it everytime and all that good stuff but the serial number is 128 lol from what ive been able to research they wear hand made but I wouldn't trade it for a new one unless i just cant find parts if needed.
Dont forget to live life for fear of death grasp each day and live it to it full otherwise it is pointless.
newwoodworker is offline
post #5 of 22 (permalink) Old 10-25-2010, 08:29 AM Thread Starter
Thanks for the replies! I've searched online for information for the type of oil needed for the oil bath. The suggestions range from 10w to 20w to 30w all the way up to 80-90w oil...
Does anyone care to add their opinion? I also thought about going synthetic?
Thanks in advance!
BTW I posted 3 pictures of how it looked as purchased. I hope to have it back together this week and looking good!
~Kristofer
post #6 of 22 (permalink) Old 10-25-2010, 08:58 AM
Hi Kristofer
I will suggest 30 w non detergent oil, you don't want it form up, the same that many compressor use..
Thanks in advance!
post #7 of 22 (permalink) Old 10-25-2010, 11:15 AM
Ralph Barker's Avatar
First Name: Ralph
Default Oils
You could try used vegetable oil from a local fast food place, so you'd be known as the burgermeister of scrolling.
Somewhere between 10W and 30W, depending on your climate, seems right to me. You want it to lubricate without hindering motion, I'd think.
Synthetic oils are mostly designed for the high-heat environment of engines and such, so I wouldn't see an advantage there. Unless, of course, you replace the motor with that from your router.
[edit]FWIW, I have a '50s-vintage Delta Homecraft scroll saw that I inherited from my father. But, it hasn't been used in decades. So, the oil discussion reminded me that I need to clean out the old oil before attempting to use it. My '80s-vintage Hegner MultiMax-2 has been seeing all the action.
- Ralph
Ralph Barker is offline
post #8 of 22 (permalink) Old 10-25-2010, 04:06 PM Thread Starter
Default Getting it together...
Thanks for the info, I ended up finding some 30w non-detergent variety at Tractor Supply...
I've got it almost together, but now am struggling to get the blade attached to the top AND bottom chuck...I am not sure if it's all there... I'll try to post some pictures of what IS there and maybe you all can tell me if I am missing something?
(edit) Jerry: Thanks for your good pictures... I noticed the way the blade attaches to yours appears to be different from mine...I think something is just missing on mine...
(edit) Also thanks BJ & Ralph for your oil suggestion...it confirmed what I was already leaning toward...
Name:	Atlas 24in Scroll Saw Side 1.jpg
Name:	Atlas 24in Scroll Saw side 2.jpg
Name:	Lower chuck 01.jpg
Name:	Lower chuck 02.jpg
Name:	Lower chuck from above 01.jpg
Name:	lower chuck from above 02.jpg
Name:	lower chuck from other side.jpg
Name:	upper assembly 01.jpg
Name:	upper assembly 02.jpg
Name:	upper chuck installed.jpg
~Kristofer
post #9 of 22 (permalink) Old 10-25-2010, 06:16 PM Thread Starter
I gave up for today and then searched online a bit more and came across an old manual for a similar Atlas jig/scroll saw....it appears I am missing the "floating jaw" shown in the diagram I attached...
I'm going to have to get creative I guess
Name:	jig saw chuck.jpg
~Kristofer
post #10 of 22 (permalink) Old 10-25-2010, 07:10 PM
HI Kristofer
Looking good, some key stock may do the trick,round it on the grinder and test for fit and then heat treat it.. then cut to the right size..but a little bit long.
Scrolling Bob N Wood Scrolling 31 04-18-2012 01:07 PM
What is wood scrolling? do you have a picture of the tool? popeyebedford Wood Scrolling 6 07-13-2007 05:02 PM
Scrolling Milt Starting Off 5 02-12-2007 03:59 PM
Tips and Tricks for Scrolling whitewolf710 Wood Scrolling 3 08-29-2006 12:40 AM
