Tip from ShopNotes - Router Forums
post #1 of 5 (permalink) Old 10-13-2006, 09:48 AM Thread Starter
Default Tip from ShopNotes
ShopNotes TIP
Scroll Saw Auxiliary Table
"Table Diagram Most of the work I do on my scroll saw involves fine cuts on small pieces.
So itís very important for the workpiece to slide easily across the table.
The problem is most scroll saw tables arenít very smooth.
Iíve tried waxing the table and found that the wax wears off pretty quickly and leaves a residue on my projects.
To solve the problem, I made a smooth-sliding auxiliary top out of a piece of Plexiglas, as in the drawing above.
The Plexiglas is the same size as the saw table and has a hole only a bit larger than the blade to provide more workpiece support.
I attached it with spray adhesive."
I did put it on my top plate and it works great but I didn't use glue (spray adhesive ) I used double sided carpet tape because I know it in time I will need to replace it with a new one, I used 1/8" clear plastic and drilled a 1/4" hole for the blade and the blade did make a small slot to run in like a guide, in the plastic that should help with blade bend.(tracking)
It should save the metal top from getting small scratches and to keep the resale up,just never know if I want to get a new one and sell the Dewalt.
But it's sure slick and works great for small parts
Good Woodworking,
Phil Huber
Online Editor, ShopNotes
http://www.woodnet.net/tips/via-email/
post #2 of 5 (permalink) Old 10-13-2006, 10:45 AM
beemerbob's Avatar
First Name: Robert
I saw that tip and have tried it in the past. My experience is that the surface of the plastic scratched easily. In no time, the surface scratched so badly that moving the piece around was difficult.
A better solution is make a 1/4 in. top for the table. Drill a hole for the blade entry that MATCHES ANY DOWEL SIZE YOU MAY HAVE AROUND. Drill the center of the dowel insert for the blade access. When the hole gets worn out, drill out the dowel and put in a new insert.
Being plywood, the top will take a good coating of Johnson's Paste Wax. If the top gets scratched, rewax it.
Bob from Northwest Florida
beemerbob is offline
post #3 of 5 (permalink) Old 10-13-2006, 11:30 AM
berry's Avatar
First Name: Berry
I'd think the dowel would try to 'climb' out of the base, how do you keep them together?
berry is offline
post #4 of 5 (permalink) Old 10-18-2006, 12:53 PM
beemerbob's Avatar
First Name: Robert
I glue the dowel to the table top. When the hole for the blade gets really ratty looking, I drill out the dowel and put in a new piece.
post #5 of 5 (permalink) Old 11-21-2006, 10:47 AM
Ive always used furniture paste wax by mini wax
and as far as the wax staining my work i wrap clear packing tape around all the wood i cut that way when i attach the pattern using spray glue i dont have to pick all the paper off afterwards it comes off in one swoop with no residue left on the wood
whitewolf710 is offline
Shopnotes #87 kenwho Jigs and Fixtures 10 01-11-2013 09:30 AM
What woodworking magazine do you like best? hitnailonhead Tools and Woodworking 24 01-21-2010 05:22 PM
ShopNote #43 Bluegillman Jigs and Fixtures 13 11-28-2004 11:12 PM
