How do you finish a portrait? - Router Forums
post #1 of 17 (permalink) Old 05-25-2012, 02:44 PM Thread Starter
First Name: Kevin
Default How do you finish a portrait?
I'm curious what does a finished portrait look like? Would you put it in a picture frame? How else would you put it on display and not have it just look like a picture in a frame?
kawisser is offline
post #2 of 17 (permalink) Old 05-25-2012, 04:17 PM
First Name: Brett
What's wrong with a frame? They are (or can be) made in thousands of ways from minimalistic to ornate...to complement the work or your decor. Photos and flat art, such as watercolors or drawings, are often matted in the frame. So, even though it's "just a picture frame" it doesn't have to look like any old picture frame. But there are frameless options, too.
Is this a photo or a painting?
Photos can be mounted between sheets of glass or acrylic and hung without a frame. Paintings on canvas are sometimes mounted on thicker strechers and are displayed without a frame. A photo can be displayed the same way by printing it on a canvas-like material. It's called a gallery wrap.
Then there's dry mounting, where the photo is pressed onto a foam core board or other substrate. The board is usually about ⅛–" thick, white, and is meant mostly for framing or other non-artistic display. But some photos are sharply displayed by mounting them on a much thicker board (" to 2", one brand name is Gatorboard) with a black foam core, exactly sized to the photo.
If you want some ideas, one of my favorite art supply sites is DickBlick.com
PetersCreek is offline
post #3 of 17 (permalink) Old 05-25-2012, 04:31 PM Thread Starter
First Name: Kevin
I've been wanting to try to make a portrait from wood. I just figured part of the art is the 3-dimensionality of it. I thought if I put it in a frame, it would take away from that.
kawisser is offline
post #4 of 17 (permalink) Old 05-25-2012, 11:32 PM
Try looking at examples of marquetry.
post #5 of 17 (permalink) Old 05-26-2012, 08:54 AM
First Name: Wayne
What I do with portraits. I cut the portrait out on my scroll saw. Then mount it to a backer board with a contrasting color so the art work shows up. I then make a spacer to between the backer board and normally stain it a flat ebony if I am using a black backer. If the portrait is 1/2 in thick I make the spacer 3/4 inch in height. Add up the thickness of the backer board, the spacer and the glass. Then make the frame to fit in size and depth. I stay with a simple frame with so as to not take away from the art work. I use a flat finish on the art work and high gloss on the frame. I hope this helps answer your question, it is not a difficult thing to do but sort of hard to describe with out a picture. The work I do like this is religious in nature and not permitted to post here.
WayneMahler is offline
post #6 of 17 (permalink) Old 05-26-2012, 10:56 AM
TwoSkies57's Avatar
Wayne, I don't think there would be any problems with posting 'religious' works. As long as your post sticks with the 'techniques' involved and not evolve into a religious commentary you are good to go. I'm sure alot of folks would like to see what your talking about.
bill
Skipper the Penguin
TwoSkies57 is offline
post #7 of 17 (permalink) Old 05-26-2012, 11:25 AM
First Name: Danella
Default posting religious work
Recently someone posted a napkin/serviette holder with a fish and greek letters - no problem. Art is Art and woodworking is the best kind of art!
Last edited by beemor; 05-26-2012 at 11:26 AM. Reason: spell check: posted - not poated!!!
beemor is offline
post #8 of 17 (permalink) Old 05-26-2012, 09:50 PM
love4god's Avatar
First Name: derek
here is one i did of jesus in a frame..godbless
love4god is offline
post #9 of 17 (permalink) Old 05-27-2012, 07:39 AM
paduke's Avatar
Nice Work!!!! and God's Blessings on you as well
paduke is offline
post #10 of 17 (permalink) Old 05-28-2012, 07:21 AM
First Name: Wayne
Here is The Crown of Thorns framed. Hope this helps.
The frame is 1 1/2 thick, rabbeted out to fit the art work. Once assembled it gives a true 3d image. The art work is 1/2 and the black spacer around it is 3/4 stained with ebony. The glass set on top of the spacer.
Tung Oil Finish query TheOakDude The Finishing Touch 3 11-09-2011 12:28 PM
Finishing the way I see it! by Derek Willis. derek willis Woodworking Articles 0 02-28-2011 08:44 AM
Water based finish over oil based finish? ffjdh The Finishing Touch 10 05-18-2010 05:54 AM
Pore Filling with Finish jimcrockett The Finishing Touch 6 07-09-2008 07:10 PM
