Cutting out letters - Router Forums
post #1 of 12 (permalink) Old 09-10-2012, 07:35 PM Thread Starter
seekertat's Avatar
First Name: Alice
Unhappy Cutting out letters
I'm trying to make a desk name plate for my son, who recently was ordained as a Youth Pastor. I am trying spiral scroll saw blades and cutting the letters out. Not doing so well as the blade seems to do a jig and I tighten it down significantly. I think near to the point of breaking.
Is there a right way to cut out letters. Maybe my blades are not right for this? I'd appreciate any advice. No matter how simple it might seem to you, I probably don't know it.
seekertat is offline
post #2 of 12 (permalink) Old 09-10-2012, 11:38 PM
First Name: Wayne
Alice
when I am cutting out letters. I normally use a #1 or #2 reverse cut blade. It keeps things smooth on both sides and is easier to control then a spiral cut blade. I also use a zero cut placement under my blade. It can be made very simple. An old playing card or thin piece of cardboard taped to the surface of the table helps protect the smaller fragile ares from breakage.
Making saw dust in Turtle Creek, PA.
Wayne
WayneMahler is offline
post #3 of 12 (permalink) Old 09-11-2012, 06:02 AM
Yep..Throw the spiral cut blades away. As you know, they cut in every direction. And if you stop to reposition your hands, or hiccup, or anything else, the blade will cut where you don't want it to.
For really thin wood, I like a #2 or 2/0. But I will also use the thinner blades on thicker wood for a smoother cut too. Skip tooth or reverse tooth blades work well.
Good luck.
Jim
jsears is offline
post #4 of 12 (permalink) Old 09-11-2012, 07:05 AM
Iceman567's Avatar
First Name: Ted
I'd chuck the spiral blades too. Used them once and that was enough. Although there are scrollers out there that love them.
Here is a chart (by Olson Blades) for some basic blade info. http://lib.store.yahoo.net/lib/yhst-...crollChart.pdf.
Here is Steve Good's website that has a name pattern maker for the scroll saw Scrollsaw Workshop. Good luck.
Iceman567 is offline
post #5 of 12 (permalink) Old 09-11-2012, 08:06 AM Thread Starter
seekertat's Avatar
First Name: Alice
Originally Posted by WayneMahler View Post
Alice
Thanks, Wayne. I'll get a few of those blades and give it a try. I know the blade does make a difference, but I've not done this long enough or consistently enough to know which blade to use.
Thanks again.
post #6 of 12 (permalink) Old 09-11-2012, 08:08 AM Thread Starter
seekertat's Avatar
First Name: Alice
Good luck.
Jim
Thanks, Jim. I had already considered throwing those spiral blades away. I appreciate the advice.
post #7 of 12 (permalink) Old 09-11-2012, 11:29 AM
kp91's Avatar
First Name: Doug
Alice,
the # 3 and #5 Olson blades are a great way to start getting a handle on your technique. They are a little more forgiving on blade tension, but still allow some fairly tight turns. Plus, I can see the teeth so I know I am putting them in the right way...
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #8 of 12 (permalink) Old 09-11-2012, 12:10 PM
stanzee's Avatar
First Name: Stan
I watched a fella giving a demo once. He did wonders with spiral blades so I thought I would give it a try. I decided that the reason he did so well was that he had lots and lots and lots (ad infinitum) of practice. Since I don't care to spend so much valuable time practicing I decided to use conventional blades. IMHO
stanzee is offline
post #9 of 12 (permalink) Old 09-11-2012, 01:40 PM
First Name: Frank
Just a quick not to add to what has already been said, the spiral blades are great for those who have time to learn to use them. I tried them and that was the end of that.
Tagwatts1 from Utah
Tagwatts1 is offline
post #10 of 12 (permalink) Old 09-11-2012, 03:36 PM
JOAT's Avatar
First Name: Theo
I'll just toss out there how I do it, when I do it. Just in case. I don't know what blades I get, but thery're a tad coarse, but make nice smooth cuts. Make curves pretty nicely, not really tight curves, but when I make curves if I can't make one tight enough, I just go back and make two or three cuts to make it as tight as I want. Then, if needed, I send the cuts smooth. Usually I don't have to sand at all, and usually just one cut does for me. But on the other hand my letters/numbers are like 2" tall usually. My stuff is not for a desk either, but on a sign post or some such, where perfaction is not such a big deal. But, however you do it, the other guys ways are probably better than mine, practice on scrap wood before you go for the gold.
JOAT is online now
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
cutting letters tjw Sign Making 6 09-21-2010 02:51 PM
cutting letters tjw New Member Introductions 4 09-17-2010 07:50 AM
Cutting out large letters RodLloyd Jigs and Fixtures 6 11-24-2004 12:24 AM
