Cutting speed - Router Forums
post #1 of 12 (permalink) Old 10-02-2012, 01:11 PM Thread Starter
L Town Graphics's Avatar
Default Cutting speed
Hey guys I've been working an a little piece and recently it seems like my cuts are going super slow, like lost to a snail slow. I've tinkered with trying a faster and slower speed which really didn't make much of a difference. I'm using a regular blade from the variety pack I bought at home depot
"the last person that was perfect was crucified"
Find all of my work both wood and vinyl on Facebook
-coming soon- www.ltowngraphics.com
L Town Graphics is offline
post #2 of 12 (permalink) Old 10-02-2012, 01:40 PM Thread Starter
I forgot to add... Im cutting 3/4" pine. Am I using the wrong blade? What speed to you suggest for optimum quality?
post #3 of 12 (permalink) Old 10-03-2012, 06:22 AM
First Name: Gerry
There is a nice blade selection chart on the Olson website; I haven't posted enough to allow posting a URL but you can figure it out from this: www dot olsonsaw dot net. It sounds like you may need a coarser blade as the one you are using may be clogging.
GerryER is offline
post #4 of 12 (permalink) Old 10-03-2012, 07:51 AM
JOAT's Avatar
First Name: Theo
What machine are you cutting "with"? That might help.
JOAT is offline
post #5 of 12 (permalink) Old 10-03-2012, 08:02 AM
First Name: Art
Dan it sounds like you are doing scroll saw work. If this is the case have you used the saw before and had better luck? For that matter have you used what ever saw you are using before and had better luck? If you have then it is probably the blade if this is the fiorst time then it is probably the saw is not up to the task.
mgmine is offline
post #6 of 12 (permalink) Old 10-03-2012, 08:06 AM
First Name: Eloy
Dan, Post what type of machine your using and if your going cross grain or with the grain or both if it is a scroll saw. There is an answer if you provide that information.
damnitboy is offline
post #7 of 12 (permalink) Old 10-03-2012, 08:37 AM
First Name: del
get some good blade's from here they are the best. Mike's Workshop English featuring: my life story, a cancer survivor, scrollsawing samples and tips, community service, list of favorite sites and Flying Dutchman fretsaw blades for sale.
also call and talk to MIKE he will tell you what you need to know
Just in case you are wondering why you have to push to keep blade going streight is because the blade's are punch out and have only set on one side fyi
del schisler
port st. lucie, florida
del schisler is offline
post #8 of 12 (permalink) Old 10-03-2012, 09:27 AM Thread Starter
It's a craftsman model 21602. Cross cuts seem to be fine, cutting with the grain of wood is where the problem seems to be
post #9 of 12 (permalink) Old 10-03-2012, 10:12 AM
Harrison67's Avatar
First Name: Harrison
Sounds like you need fewer TPI.
Harrison
Harrison67 is offline
post #10 of 12 (permalink) Old 10-03-2012, 08:58 PM
Iceman567's Avatar
First Name: Ted
Dan, I like to use a #5R, which is a reverse tooth. It will cut fairly fast in 3/4" pine and should leave a fairly smooth edge and no tear out on the bottom. Crosscut will be faster than going with the grain. Speed from 1000 - 1800. You'll have to experiment as every saw (and owner) is different. Keep the blade tension in check. Tight enough to keep the blade from wandering and not too tight so it SNAPS during a cut. That'll get your attention!
The smaller blades will require less tension than the larger ones. I have a Dewalt Saw and usually ~twang~ the blade...usually to a C Sharp. LOL!
I'll second Flying Dutchman Blades from Mike's Workshop. That's all I use.
It will take a little trial and error, but looking at your sign work you won't have a problem.
Enjoy the saw other than cut-outs for your signs. Lot's of fun.
The trouble with quotes on the internet is that you never know if they are genuine. - Abraham Lincoln
Iceman567 is offline
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
bit size verses cutting speed Remain Router Bits - Types and Usage 2 03-16-2011 10:17 PM
Ski question os smoothing end grain, bit, speed, etc TanOak Portable Routing 4 11-07-2010 09:03 AM
What to choose? Need a knew Lrg. Router and plate set-up toadsage Table-mounted Routing 5 11-10-2009 10:24 PM
Raised Panel Cutting Speed robert225 Tools and Woodworking 2 02-14-2005 01:17 PM
