convert pin type saw to plain end blades - Router Forums
post #1 of 7 (permalink) Old 01-15-2013, 05:04 PM Thread Starter
roxanne562001's Avatar
First Name: Roxanne
Default convert pin type saw to plain end blades
Hello all
My friend gave me what looks to be an almost new Craftsman scroll saw. My old saw which died had 5" plain blades and I have several on hand The only thing I see wrong is it only accepts the pin type 5" blades. What would you recommend sticking with pin blades or using an adapter. If I go with an adapter which one is best?
Roxanne
roxanne562001 is offline
post #2 of 7 (permalink) Old 01-15-2013, 06:21 PM
First Name: Wayne
Roxanne
I prefer pin-less blades. They require smaller access holes and you can get them in sizes in not available with pinned blades. I am not aware of any adapters, but all my saws took both styles. Did you get the owners manual with the saw? If not you can search for it on craftsman's site. This should help overall with the saw.
Making saw dust in Turtle Creek, PA.
Wayne
WayneMahler is offline
post #3 of 7 (permalink) Old 01-16-2013, 06:52 AM
williamm's Avatar
I just got a saw for Christmas and haven't really used it yet. It did come with an adaptor for the blades without pins.
It is a Rockwell and they may sell the adaptor alone.
williamm is offline
post #4 of 7 (permalink) Old 01-16-2013, 07:37 AM
First Name: Art
If I had it to do over again I would go with the pin type. The reason is that it is impossible for the blade to slip out which is not the case with the pinless type. Yes the hole has to be made larger but unless you do that type of work often it shouldn't be a problem.
mgmine is offline
post #5 of 7 (permalink) Old 01-16-2013, 08:36 AM
First Name: Duane
Might try here...
Scroll Saw Retrofit Items
Dmeadows is offline
post #6 of 7 (permalink) Old 01-16-2013, 08:39 AM
First Name: Duane
Properly installed/tightened blades should not slip! Anything else that will cause a pinless blade to pull out will probably break a pinned blade!
Dmeadows is offline
post #7 of 7 (permalink) Old 01-16-2013, 11:34 AM
JOAT's Avatar
First Name: Theo
My Craftsman scroll saw is probably close to 20 years old now. It will take pin or pinless blades, so I'm surprised your's won't. But all I use are the pinned blades, much less of a pain to use, and I don't cut any small holes anyway - and on the very few occassions I do cut holes, I just cut in from the side, do the hole, and back out.
JOAT is online now
End Mills vs.Rrouter Bits For Mortising. Gaia Router Bits - Types and Usage 8 07-03-2010 12:37 PM
Band Saw vs Scroll Saw? kolias Tools and Woodworking 42 05-14-2009 05:43 AM
fences the plain type xplorx4 Table-mounted Routing 15 12-15-2008 06:13 PM
