Scroll saw info - Router Forums
post #1 of 9 (permalink) Old 06-05-2013, 08:24 AM Thread Starter
bileo4's Avatar
Default Scroll saw info
HI, I'm new to the forum. I have a Bench Pro scroll saw,model SSW18. I can't find any info on the computer or from local tool companies. Does any one have any info about this saw and who I could get parts from. It would be greatly appreciated.
bileo4 is offline
post #2 of 9 (permalink) Old 06-05-2013, 05:24 PM
Big Steve's Avatar
First Name: Steve
Bill, I suggest you try at Scroll Saw Woodworking & Crafts Message Board
There are a lot of great people there too! That is my other main forum haunt.
Steve
Richmond, Virginia
Big Steve is offline
post #3 of 9 (permalink) Old 07-24-2014, 08:58 AM
First Name: Dennis
Can someone answer this question.
What do you use to trace on package tape to make a pattern. I've used a pencil and I can not see the pencil marl to cut the pattern. So which is best to use. And where could I get it...Dennis
dslote is offline
post #4 of 9 (permalink) Old 07-24-2014, 11:13 AM
Gaffboat's Avatar
First Name: Oliver
I make a paper pattern and use spray glue to attach it to the wood. Then I cover it with a layer of packing tape to help prevent the paper from getting fuzzed up when cutting and keep the line clean.
When finished cutting, just peel off the tape and give the piece a quick swipe with some mineral spirits on a rag to remove any paper still glued to the surface.
If you prefer to draw your pattern on the tape itself, try using an extra fine point Sharpie pen.
Gaffboat is offline
post #5 of 9 (permalink) Old 07-24-2014, 02:39 PM
berry's Avatar
First Name: Berry
Another place to ask this questions is scrollsawvillage.com
Nice international community there.
May the grain be ever in your favor.
berry is offline
post #6 of 9 (permalink) Old 07-24-2014, 02:40 PM
berry's Avatar
First Name: Berry
I use the process Oliver outlined.
berry is offline
post #7 of 9 (permalink) Old 07-28-2014, 08:05 AM
First Name: Dennis
Hi Oliver
Thanks for the advice, but the object was to use the piece I cut off as a guide to trace the next piece to cut off. I used a pen marker and let it dry but moving around on an angle is not easy. Especially the first time. I've never done this before making a bowl. Maybe I shall try paint with a pen like brush. I'll have to experiment and see what happens...Dennis
dslote is offline
post #8 of 9 (permalink) Old 08-09-2014, 07:29 AM
WHAT is it?
Hermansclork892 is offline
post #9 of 9 (permalink) Old 08-11-2014, 07:36 AM
Big Steve's Avatar
First Name: Steve
Hi Oliver
If you are trying to make a scrollsaw bowl I strongly suggest Carole Rothman's book: "Wooden Bowls from the Scroll Saw"
Great book!
Steve
Richmond, Virginia
PORTER-CABLE 16" Variable Speed Scroll Saw with Stand Noob Wood Scrolling 18 03-03-2012 06:01 AM
Making a Custom Scroll Saw work surface wbh1963 Wood Scrolling 3 01-29-2012 04:46 PM
Scroll Saw Info lam23m Wood Scrolling 0 01-03-2010 03:57 PM
Scroll Saw Help CanuckGal Tools and Woodworking 13 04-04-2009 10:00 AM
Help identify scroll saw & Band saw Kristin D Tools and Woodworking 11 11-29-2007 09:11 PM
