Blade Recommendation.... - Router Forums
post #1 of 11 (permalink) Old 03-10-2007, 12:43 PM Thread Starter
challagan's Avatar
Default Blade Recommendation....
What blade do you scroll guru's recommend for 1/4 and 3/8 hardwood? Not double stacked, just singles. Also if I was using 1/8 and 1/4 hardwood plywood what would size blade would you use for that?
Thanks,
http://iowacarver.tripod.com/
challagan is offline
post #2 of 11 (permalink) Old 03-10-2007, 01:28 PM
Hi Corey
I'm not a guru but I sure like FD-SR #3 & #5 blades I got from Mikes #3 will cut 3/4" thick walnut/maple/plywood ver. just like a butter and no sanding needed after the cut.
You can find the FD-SR blades in town I'm sure but the ones from Mike are better than the ones I found in town.(last longer and stay sharper)
Check out the links below and the Q & A link for sure.
http://www.mikesworkshop.com/index.htm
http://www.mikesworkshop.com/freecaps.htm
http://www.mikesworkshop.com/Q&A-FP.htm
Bj
Thanks,
post #3 of 11 (permalink) Old 03-10-2007, 01:46 PM
Joe Lyddon's Avatar
First Name: Joe
I agree... Mike carries the best scroll blades money can buy...
He is a great source of information too...
You could ask him the same question (for a 2nd. opinion )... and probably get the same answer.
Have Fun,
Joe
Alta Loma, CA
www.WoodworkStuff.net
Joe Lyddon is offline
post #4 of 11 (permalink) Old 03-10-2007, 02:07 PM Thread Starter
challagan's Avatar
Thanks guys, I have a selection of FD blades. Just wasn't sure what blades would work best in these thinner materials. I got the most out of the following link which was on Mikes page:
http://www.mikesworkshop.com/DaveG.h...de%20Selection
post #5 of 11 (permalink) Old 03-10-2007, 02:28 PM Thread Starter
challagan's Avatar
BJ, have you scrolled any 1/2 inch MDF and if so what did you find worked best for it?
Thanks!
post #6 of 11 (permalink) Old 03-10-2007, 04:38 PM
Joe Lyddon's Avatar
First Name: Joe
Cool
Corey,
Thank you for that link!!
I had missed it before...
I just added it to my website... under Jigs & Tools.
That's a good one!
Have Fun,
Joe
Alta Loma, CA
post #7 of 11 (permalink) Old 03-10-2007, 05:28 PM
Same ones (FD-SR #3 blade) I cut 1/4" and 1/2" all the time for templates and it cuts it so clean you can hardley see it when you put the parts together as one again.
Bj
Thanks!
post #8 of 11 (permalink) Old 03-10-2007, 05:42 PM Thread Starter
challagan's Avatar
Thanks BJ, got a dozen of those. That's what I want to do is make templates. About the only thing my scroll saw will get used for these days.
post #9 of 11 (permalink) Old 03-10-2007, 06:06 PM
they do like to wander to one side(right side) a bit in the MDF stock but that's true for most scholl blades also.
Bj
post #10 of 11 (permalink) Old 03-10-2007, 08:49 PM Thread Starter
challagan's Avatar
Yes that is pretty typical with scroll saws to get that wander to the right, you have to be ready for that right off as you start your cut. How did the box turn out?
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 4 04-10-2009 12:27 PM
which rip blade to get? rprice54 Tools and Woodworking 11 06-15-2008 06:51 AM
Forest 10" 80 tooth Chopmaster Blade rstermer Tool Reviews 0 05-13-2008 02:31 PM
Saw Blade Tip bobj3 Lobby 1 09-21-2007 09:58 AM
Blade Questions RustyW Tools and Woodworking 16 12-30-2006 05:45 AM
