Inkscape Issue - Router Forums
post #1 of 3 (permalink) Old 01-30-2014, 08:52 PM Thread Starter
berry's Avatar
First Name: Berry
Default Inkscape Issue
I've downloaded Inkscape and I am following a set of tutorials on YouTube.
I'm running Windows 7 - 64bit. The boarder around the work area, where all the tools are, dialog boxes etc is a dark gray and there is precious little contrast so with my old eyes I'm having a problem seeing the icons. On the tutorials the area is almost a white background.
So does anyone know how to change this? I'd be eternally grateful.
May the grain be ever in your favor.
berry is offline
post #2 of 3 (permalink) Old 01-31-2014, 06:03 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Berry I run W7, 64bit and I don't see what you are seeing, and it looks like all your icons are very small so if all of the icons are very small then you need to change the screen resolution, so my screen resolution is 1280x960 but if you set it to one with smaller numbers then the icons will look bigger, you should write down what they are so you can set it back if you have to but when the screen resolution gets changed then windows should give you a little look at the new settings and then ask you if you want to keep it or not and if it looks OK to you then say yes, also I don't like to have a lot of icons laying on my desk top as they get in the way of my pic of Buffy the vampire slayer so I put them all in a folder that I call 'Icons', still I just don't like them all laying around as they look messy. N
neville9999 is offline
post #3 of 3 (permalink) Old 01-31-2014, 08:49 AM
TwoSkies57's Avatar
Berry, this might answer your question:
Change Default Page Layout and Settings for Inkscape
Skipper the Penguin
TwoSkies57 is offline
ShopNotes issue 121 Router Lift techneck1324 Jigs and Fixtures 9 11-22-2016 08:04 AM
IP Address issue bozee89 Lobby 2 08-13-2013 07:45 PM
mach2/3 +y multi-pass issue fireneuf CNC Routing 4 02-04-2013 04:16 AM
A Shipping Issue With Grizzly Jerry Bowen Lobby 12 05-13-2012 12:28 PM
New Table Saw Issue CanuckGal Tools and Woodworking 30 01-01-2009 08:46 AM
