Router Forums (https://www.routerforums.com/forum.php)
-   Wood Scrolling (https://www.routerforums.com/wood-scrolling/)
-   -   Saw Bouncing (https://www.routerforums.com/wood-scrolling/77969-saw-bouncing.html)
OutoftheWoodwork 10-11-2015 03:00 PM
Saw Bouncing
Anyone who can help with my Excalibur - it's bouncing so bad I can't use it-i know something went loose I'm sure but d*mn if I know what it is
DominikPierog 10-11-2015 06:18 PM
I sent back to the distributor. It cost 1/3 of the value of a new saw. They fixed but there are also some new inconveniences. Spoiled tilt mechanism.
Cherryville Chuck 10-11-2015 07:29 PM
They were supposed to fix it, not create new problems. Complain and suggest they pay shipping this time. Otherwise you will let everyone on this forum know about the poor CS.
SteveMI 10-11-2015 08:32 PM
If it is making a mechanical "knocking sound" along with the vibration when you are not cutting anything, it may be the lower clamp. I found on my Excalibur that if the lower adjusting knob you turn isn't level with the floor then it will hit the bottom of the table when running. To adjust it you need to turn the turn the set screw on the left side (as you are facing it the saw). Different number blades are thicker than others which causes the problem depending on the blade, a #3, #5, #7 will cause the adjusting knob to be in a different orientation. Looking from the side at the knob should be at 9:00 to 3:00 clock orientation. If it is at 12:00 to 6:00 clock orientation it will probably knock and cause the table to vibrate.
If this isn't clear, I can post a picture tomorrow.
Steve.
OutoftheWoodwork 10-12-2015 09:59 AM
Steve.
No noise Steve just bouncing. It did this before but I can't remember where the adjustment had to be made to stop the severe bouncing or shaking. In addition, I can't cut at 45 degree like I should be able to, because it rubs/cuts the table. Done that since I got it
OutoftheWoodwork 10-12-2015 02:47 PM
Created this yesterday, but couldn't upload from anywhere. Let's hope this works
SteveMI 10-12-2015 04:41 PM
1 Attachment(s)
In your video I can hear the knocking of the knob hitting the table, that is also why the table is bouncing at the front. I just went out an took a picture of mine. It is close to getting the knock/vibration. If that knob points are vertical, then it does the same as yours.
Tilting the table down on the right only makes this worse.
Steve.
OutoftheWoodwork 10-12-2015 05:46 PM
Without the knob in there it still bounces Steve. It's another area that likes to come loose that needs tightening but I don't remember where. Had to have it done before; and with all the moving around we've done I'm not surprised it's loose again
DominikPierog 10-13-2015 06:48 PM
This table is real bouncing > flexible so much?
Or is camera synchronization effect?
OutoftheWoodwork 10-13-2015 09:34 PM
I think that's the camera with the wave effects. But the table is shuttering up and down violently. I had to press down with all my might while pushing the wood to cut
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
