Saw Bouncing - Router Forums
 6Likes
post #1 of 16 (permalink) Old 10-11-2015, 02:00 PM Thread Starter
OutoftheWoodwork's Avatar
First Name: Barb
Default Saw Bouncing
Anyone who can help with my Excalibur - it's bouncing so bad I can't use it-i know something went loose I'm sure but d*mn if I know what it is
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
post #2 of 16 (permalink) Old 10-11-2015, 05:18 PM
Country: Poland
First Name: Dominik
I sent back to the distributor. It cost 1/3 of the value of a new saw. They fixed but there are also some new inconveniences. Spoiled tilt mechanism.
DominikPierog is offline
post #3 of 16 (permalink) Old 10-11-2015, 06:29 PM
They were supposed to fix it, not create new problems. Complain and suggest they pay shipping this time. Otherwise you will let everyone on this forum know about the poor CS.
post #4 of 16 (permalink) Old 10-11-2015, 07:32 PM
SteveMI's Avatar
First Name: Steve
If it is making a mechanical "knocking sound" along with the vibration when you are not cutting anything, it may be the lower clamp. I found on my Excalibur that if the lower adjusting knob you turn isn't level with the floor then it will hit the bottom of the table when running. To adjust it you need to turn the turn the set screw on the left side (as you are facing it the saw). Different number blades are thicker than others which causes the problem depending on the blade, a #3, #5, #7 will cause the adjusting knob to be in a different orientation. Looking from the side at the knob should be at 9:00 to 3:00 clock orientation. If it is at 12:00 to 6:00 clock orientation it will probably knock and cause the table to vibrate.
If this isn't clear, I can post a picture tomorrow.
Steve.
SteveMI is offline
post #5 of 16 (permalink) Old 10-12-2015, 08:59 AM Thread Starter
First Name: Barb
Steve.
No noise Steve just bouncing. It did this before but I can't remember where the adjustment had to be made to stop the severe bouncing or shaking. In addition, I can't cut at 45 degree like I should be able to, because it rubs/cuts the table. Done that since I got it
Barb
Mark Twain
Henry A. Kissinger
post #6 of 16 (permalink) Old 10-12-2015, 01:47 PM Thread Starter
First Name: Barb
Created this yesterday, but couldn't upload from anywhere. Let's hope this works
Barb
Mark Twain
Henry A. Kissinger
post #7 of 16 (permalink) Old 10-12-2015, 03:41 PM
SteveMI's Avatar
First Name: Steve
In your video I can hear the knocking of the knob hitting the table, that is also why the table is bouncing at the front. I just went out an took a picture of mine. It is close to getting the knock/vibration. If that knob points are vertical, then it does the same as yours.
Tilting the table down on the right only makes this worse.
Steve.
SteveMI is offline
post #8 of 16 (permalink) Old 10-12-2015, 04:46 PM Thread Starter
First Name: Barb
Without the knob in there it still bounces Steve. It's another area that likes to come loose that needs tightening but I don't remember where. Had to have it done before; and with all the moving around we've done I'm not surprised it's loose again
Barb
Mark Twain
Henry A. Kissinger
post #9 of 16 (permalink) Old 10-13-2015, 05:48 PM
Country: Poland
First Name: Dominik
This table is real bouncing > flexible so much?
Or is camera synchronization effect?
post #10 of 16 (permalink) Old 10-13-2015, 08:34 PM Thread Starter
First Name: Barb
I think that's the camera with the wave effects. But the table is shuttering up and down violently. I had to press down with all my might while pushing the wood to cut
Barb
Mark Twain
Henry A. Kissinger
