Breaking blades while pivoting wood - Page 2 - Router Forums
 6Likes
post #11 of 13 (permalink) Old 11-23-2015, 01:54 PM Thread Starter
Thanks for all the help guys. I have an Excalibur saw and am trying different blades. So far the pause, pivot and cut method seems to be working. Well less blade breakage.. lol... I know its a learning experience. Just scares the heck out of me when that blade snaps.... I am going to try different Olsen blades and maybe the spiral blades. I purchased and assortment to try. Thanks for posting the blade chart....
picardn is offline
post #12 of 13 (permalink) Old 11-24-2015, 09:29 AM
bobditts's Avatar
First Name: Bob
The size of the blade is a huge factor. If you are trying to pivot 90 degrees with a #7 blade, chances are you will snap it. A #2 blade should pivot no problem. The thickness of the wood is a big factor as well. The thinner the wood, the easier on the blade it will be.
Follow me on Instagram at #bobditts
bobditts is offline
post #13 of 13 (permalink) Old 12-01-2015, 01:48 PM
Wildwood's Avatar
Country: South Africa
First Name: Rob
I have used many makes of blade over the years, but since discovering Flying Dutchman blades about 10 years ago, I use no others. The only time I ever have a blade snap on me is through metal fatigue after a lot of use.
Available from Mike's Workshop.
https://www.mikesworkshop.com/blades.htm
Wildwood is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
New to wood working and to this forum. jaithran New Member Introductions 9 11-25-2014 01:50 AM
Questions about wood Pallets and moisture GoonMan Tools and Woodworking 2 07-05-2005 08:11 PM
