Improved Lighting For My Scroll Saw - Page 3 - Router Forums
 22Likes
post #21 of 33 (permalink) Old 12-09-2015, 05:59 PM
First Name: Ed
I will have to check the post to see what you are making, good idea on the christmas presidents. I am pretty well cover for dust collection. I have a dust collector with the upper paper filter and using a separatorand also have a air filter unit and connect my handheld tools to a vac, or the DC.
I'm in my mid 60's and between a few years in the engine room while in the Navy, working as a laborer and being involved in woodworking and old cars for most of my life. I figure my lungs are getting near full of all kinds of stuff so I recently got serious about dust collection.
herrwood is offline
post #22 of 33 (permalink) Old 11-27-2016, 06:26 PM
I finally looked at the pictures of the scroll saw and really LIKE the use of flat aluminum for mounting the light. Easy to work with and plenty strong. I have some thick, 2 inch L shaped stock that would be very easy to mount on practically anything. I have one more extremely bright LED fixture to set up and your idea really clicks.
DesertRatTom is online now
post #23 of 33 (permalink) Old 11-27-2016, 07:10 PM
paduke's Avatar
I have this https://www.uline.com/Product/Detail...Q&gclsrc=aw.ds mounted on my scroll saw cabinet. I sit on a stool and am able finally see those lines
paduke is offline
post #24 of 33 (permalink) Old 11-28-2016, 12:28 PM
Dejure's Avatar
First Name: Kelly
I was doing great, copying your idea, until I turned the saw on and watched the light assembly go up and down a million times, before rocketing across the room.
May I shouldn't have tied it to the arm that moved the blade?
coxhaus likes this.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #25 of 33 (permalink) Old 09-18-2019, 12:15 PM
Dejure's Avatar
First Name: Kelly
Sold the single speed Hegner I bought for two hundred twelve years ago for four hundred. Bought an RBI for two, added a couple things and sold it to a buddy for what I had into it and used that money to buy a variable speed Hegner. All this and answering questions about the saw got me to looking it all over again. A LOT more information out there on using them today and I'm actually enjoying the critter for the first time.
The LED light I bought for the RBI went out the door with it, so the new, used Hegner didn't have one. The problem [of lack of lighting] was solved by that I, a while back, bought several sewing machine lights as task lights for various tools. For example, I mounted one on the head-stock and one on the tail stock of my lathe and they provide the light I need to tend details, when turning. I had a couple more I was going to mount on my miter (right and left), but hadn't got to yet. Because the Hegner hold down is iron, the rare earth magnets attach to it fine and it seems to be doing the job.
Just for reference, these run about nine to fourteen dollars (get the ones with the most LED's, which, I believe, is about forty-five).
Name:	Hegner & Light-2.jpg
Name:	Hegner & Light-4.jpg
Scraps are a myth.
Dejure is offline
post #26 of 33 (permalink) Old 09-19-2019, 02:53 PM Thread Starter
CharleyL's Avatar
First Name: Charley
Wow, you have been digging into ancient history.
Using two lights is better, because it almost completely eliminates the blade shadows, so you can actually see where the blade is cutting. Going with LED lights also eliminated the forehead burns that I kept getting when I was using the halogen lights. I still use the same two light system and vacuum when using my scroll saw, but several years ago my son brought me a metal 20 gallon grease barrel (grease came in a plastic bag inside) and I made a lid from two layers of 3/4 cabinet birch ply to attach my Dust Deputy to it. No more bucket implode incidents, but the barrel emits an oil can type pop sound sometimes when I start the vacuum.
Put two lights on your scroll saw, one shining down at about a 45 deg angle on each side of the blade. I think you will be very pleased with the result.
Charley
Central North Carolina
CharleyL is offline
post #27 of 33 (permalink) Old 09-19-2019, 05:42 PM
This is a well aged string. I found some small, 50 watt equivalent LED reflector bulbs that screw into a standard light socket. I bought $2 gooseneck lamps at a second hand store, took the bases off and mounted them using the threaded shaft. Works great, stays cool, a huge amount of light, switches on the back of each reflector. Or pop for a little more to get miniature relflector new. These throw a fairly sharp edged shadow, which actually helps locate the blade position. I'd probably affix the mounting plate behind the machine, connected to the stand, so the goosenecks extend over the blade.
post #28 of 33 (permalink) Old 02-03-2020, 05:29 PM
Rusty Nesmith's Avatar
First Name: Rusty
When you get old like me you will want one of these.
kp91 likes this.
Rusty
West Virginia
Rusty Nesmith is offline
post #29 of 33 (permalink) Old 02-03-2020, 06:48 PM Thread Starter
CharleyL's Avatar
First Name: Charley
Wow, this is ancient history.
My intent was to show that providing a bright LED light on each side of the blade cutting point, high enough not to get in the way but angled down at about 45 degrees to illuminate the blade from both sides. This nearly eliminates blade shadows and makes it much easier for me to see where the blade is cutting. I frequently was catching myself steering the work to follow the blade shadow and not the blade itself. You cannot eliminate the blade shadow with only one light, unless it is in front of and centered on the blade, but this is the exact point where you want to put your head and eyes. I too use magnification when doing very small work, but it has no light and is attached to a head band. A stationary magnifying glass has not worked for me. The lens abbarations
give me headaches, because I'm constantly moving my head around when I cut to see the cut from different angles. If you can work with a stationary lens you are better than me.
Each year the company that supplies the lights that I'm using changes the design slightly, but they are producing a similar light and they are in my local Lowes store. They don't look exactly the same, because the lamp head is a slightly different shape.
Go with two lights of whatever light you choose, and aim each one at the cutting point of the blade from each side. I'm quite certain that you will like the result, whether you use a magnifier or not.
Charley
CharleyL is offline
post #30 of 33 (permalink) Old 02-05-2020, 11:54 AM
First Name: Rusty
Sorry I didn’t notice the date. It was at the top of the list so I thought it was recent.
Rusty
West Virginia
Scroll saw stand question. JOAT Wood Scrolling 15 02-13-2014 03:46 PM
PORTER-CABLE 16" Variable Speed Scroll Saw with Stand Noob Wood Scrolling 18 03-03-2012 06:01 AM
Making a Custom Scroll Saw work surface wbh1963 Wood Scrolling 3 01-29-2012 04:46 PM
Scroll Saw Help CanuckGal Tools and Woodworking 13 04-04-2009 10:00 AM
Help identify scroll saw & Band saw Kristin D Tools and Woodworking 11 11-29-2007 09:11 PM
