Elm slab - Page 2 - Router Forums
 23Likes
post #11 of 23 (permalink) Old 04-29-2017, 08:16 AM Thread Starter
First Name: Andy
I've cut out my table tops, picture below. Also a couple of the nicer offcuts. I still have a 3ft by 1ft chunk of slab left as well. So I'll need to think up something to do with those.
The tops turned out to have a bit of twist in them, about 1/8" corner to corner on the largest one. I'm not really sure what I can do about that, not a lot I suspect. A bit of cupping could be pulled out with a frame rail underneath, but a twist, not so much. The only way I can think of is to accept the slight twist and scribe the frames to match it.
kp91, Cherryville Chuck and old55 like this.
AndyL is offline
post #12 of 23 (permalink) Old 04-29-2017, 01:14 PM
Mayo.Mick's Avatar
Country: Ireland
First Name: Michael
Use the offcuts to route a sign maybe? Really nice grain
Mayo.Mick is offline
post #13 of 23 (permalink) Old 05-01-2017, 01:56 AM
Can you hand plane the twist out? Use the planer for the other side. Use a 1x3 or possibly smaller piece to truss You might also use the cutoffs to make more delicate, tapered legs. That is such a beautiful piece of wood.
Here's a demo of flattening twist with a hand plane.
Here's a video of flattening a twist with a power planer.
Here is a better video of hand planing.
With a small piece, you can use plenty of carpet tape to hold the piece in place.
DesertRatTom is online now
post #14 of 23 (permalink) Old 05-03-2017, 07:22 AM Thread Starter
First Name: Andy
Unfortunately I don't think I have the thickness to do that Tom. I'd need to take 1/8" off both sides, which would leave me with a top 5/8" thick.
DesertRatTom likes this.
AndyL is offline
post #15 of 23 (permalink) Old 05-03-2017, 12:58 PM
Hi, I have a set of near antique nesting tables with very thin tops, and tapered and turned legs that are quite beautiful and stable. There are 2 inch hardwood trusses (frames) on the back and two sides of each of these tables, with an open front for the next table to slide in. Those trusses will help prevent further twisting, especially at 5/8ths thickness.
You might also consider (after removing the twist, creating a second layer below to add strength and thickness, a less expensive piece of the same material could be used for this purpose. Attached is a picture of the tables I have (but in better condition). The legs are delicate, but you could simply use tapered legs. Or straight legs like the other example.
I'm posting this because your stock is really beautiful, and would be perfect for a more special looking set than what your original design shows And the techniques required are really not particularly more complicated. Of course you could use well concealed pocket screws and glue, which would simplify the construction.
Name:	tables nested.jpg
Name:	table nesting-1.jpg
JFPNCM likes this.
post #16 of 23 (permalink) Old 12-02-2017, 12:10 PM Thread Starter
First Name: Andy
Hello again everyone. I've been off the forum for a while, as for one reason or another I haven't found much time for woodworking this year. But I did eventually finish the tables, here are some pictures. The frames are ash and the finish is Danish oil followed by a coat of wax.
The most tedious bit of the project was filling all the little cracks and holes in the highly-figured elm with epoxy. Every time I'd scrape it back and find bubbles or incompletely filled holes, or ones I'd missed. I think I went over each top about 4 times.
AndyL is offline
post #17 of 23 (permalink) Old 12-02-2017, 12:21 PM Thread Starter
First Name: Andy
Here's the shipping crate I made to ship the tables to my sister. 1x3 rails pocket-screwed to 2x2 legs, hardboard panels, and some tongue-and-groove boards for the top. I figured if I put hinges and catches on it instead of just screwing the top down, maybe she'll find some use for the crate as storage.
AndyL is offline
post #18 of 23 (permalink) Old 12-02-2017, 12:24 PM
Wow, those turned out really nice. I love nested tables, the ones I have my parents bought back in the early 1930s. There are a lot of very old sycamores that were slightly damaged in a forest fire a few miles from here. I sure wish I could harvest them, but they're on public land.
post #19 of 23 (permalink) Old 12-02-2017, 01:35 PM
old coasty's Avatar
First Name: Bob
Really great job. The look of the tops is outstanding.
old coasty is offline
post #20 of 23 (permalink) Old 12-04-2017, 02:25 PM
First Name: Quenten
Down here all you do is get a permit to harvest from the state. Not a big deal, it's only good for dead trees down here though. Typically for firewood.
Tonto1 is offline
Flattening a Slab tomp913 Tools and Woodworking 48 07-29-2015 10:31 AM
Reclaimed Elm Coffee Table Billy Boy Show N' Tell 8 09-20-2013 07:43 PM
Jig suggestions for routing a peak into a slab of wood slowdrip Jigs and Fixtures 5 10-14-2009 10:47 AM
wood stains to give appearance of Elm TWheels The Finishing Touch 5 08-08-2008 03:10 PM
trueing an irregular slab redro Tools and Woodworking 1 08-07-2005 01:16 PM
