Baltic Birch Plywood Thickness Question - Router Forums
 11Likes
post #1 of 16 (permalink) Old 07-30-2017, 09:42 AM Thread Starter
Contributor of the Month
Default Baltic Birch Plywood Thickness Question
Is 1/2 inch Baltic Birch a full 1/2 inch thick?
JIMMIEM is offline
post #2 of 16 (permalink) Old 07-30-2017, 09:48 AM
hawkeye10's Avatar
First Name: Don
No!!! You can easily measure it with a rule.
Herb Stoops likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 16 (permalink) Old 07-30-2017, 09:57 AM
BalloonEngineer's Avatar
First Name: Richard
Generally “real” (imported European/Russian) Baltic birch is made to metric sizes. 12mm is often sold as 1/2”, but would be about .03 undersized. I believe Appleply is available in inch sizes. I have bought strips sold for drawer sides that did measure a true 1/2”. Best idea is to measure your actual stock.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 16 (permalink) Old 07-30-2017, 10:44 AM
no...
it's in millimeters.. 12mm or .47''...
File Type: pdf Baltic Birch Plywood Specifications.pdf (36.2 KB, 153 views)
Stick486 is offline
post #5 of 16 (permalink) Old 07-30-2017, 02:29 PM
TWheels's Avatar
From my source, Rockler, Baltic birch plywood is in fact the stated thickness, according to my calipers.
Herb Stoops and bryansong like this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #6 of 16 (permalink) Old 07-30-2017, 03:34 PM
MT Stringer's Avatar
I measured a piece I have cut for drawer stock. It measures 31/64ths on my calipers. That's pretty close to 1/2 inch in my book...12.35mm... .4860 inches.
When I build a drawer and cut a 1/4 inch rabbit, it splits the center ply of the work piece.
MT Stringer is offline
post #7 of 16 (permalink) Old 07-30-2017, 03:51 PM
Gene Howe's Avatar
First Name: Gene
I guess it's where you buy it.
I have some that measures right at 1/2" and some that are a full 3/4". And, then there are a few sheets that are a bit less. Probably got them at different suppliers. Can't remember.
MEBCWD and Herb Stoops like this.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #8 of 16 (permalink) Old 07-30-2017, 04:07 PM
JOAT's Avatar
First Name: Theo
If it is listed in the stack as 1/2" and it is 3'4", it has been placed in the wrong stack. Just one of the reasons I always have a tape measure in a vest or jacket pocket.
Fortunate for me, 99.999% of my projects don't call for anything as high quality as Baltic birch, along with the extra expense. AND, doesn't need to be dead on at 1/2", just close. Actually I could even use 1/4" or 3/4" - but using 1/4" would mean making a lot more pieces to get the right thickness, and the 3/4" would give thicker projects with the look thrown off. And, even 3/8" would work, but again, the look would be off in the end. So, 1/2", or close, it is.
Gene Howe and Herb Stoops like this.
JOAT is online now
post #9 of 16 (permalink) Old 07-30-2017, 04:36 PM
I buy mine from a hardwood dealer in Houston. They have all sizes from 1/8th up to 3/4. I don't think I have ever looked for anything thicker. But I have bought some 3/8th inch, and still have a few scraps left from a previous project.
post #10 of 16 (permalink) Old 07-31-2017, 09:11 AM
MEBCWD's Avatar
I buy from several different places especially if they have a good sale going on. I had one shipment of 1/2" panels that were two different sizes, 0.025 difference in size and you could look at the panels and tell which ones were which buy a slight color difference in the materials.
It all depends on where it is manufactured, what company manufactured it, where you buy it and in some instances how and where it was stored.
I think the most important thing here is that it is best to measure each panel before use so you can adjust measurements of the project if needed so you don't have one of those "why doesn't this fit' moments when you are almost finished with the project.
MEBCWD is offline
Template thickness question atmguru222 Guide Bushings and Templates 4 02-27-2011 08:20 PM
Question about acrylic thickness sofasurfer Jigs and Fixtures 10 02-08-2010 10:39 PM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Baltic Birch Plywood Issue - Please Advise Plywoodny Wood Species 17 10-20-2009 01:46 PM
