Another driftwood id please - Page 2 - Router Forums
 7Likes
post #11 of 26 (permalink) Old 09-17-2018, 12:38 AM Thread Starter
At the moment my biggest tank is only a 29 but I live in an apartment with unknowing landlords so I can’t go huge yet
DaninVan likes this.
Brendannn209 is offline
post #12 of 26 (permalink) Old 09-17-2018, 01:52 AM
Ha! As a former landlord, you're busted!
DaninVan is offline
post #13 of 26 (permalink) Old 09-17-2018, 01:59 AM
Brendann the comment made about being a member under two user names is because we occasionally get spammers and trolls who do just that. You are the second person very recently to request a driftwood ID and the circumstances were extremely similar so it was just a bit suspicious but no worries. Welcome to the forum.
I was a logger in BC for 25 years and near the end of that time I worked for the BC Forest Service and needed to have a log scaler's license. This required that I be able to identify the local log species just by looking at the wood and I was quite good at that after looking at them while logging all the years earlier. Despite that knowledge there is only one local tree species that I can identify as driftwood and that is red cedar. Some of the others I might be able to identify if I cut an end off and the water, sun, and aging process hasn't altered the wood too much from the original state. As Dan's article said, don't use any softwoods. You might be able to tell if is a softwood by carving a decent sized chip out of it and smelling it to see if you get anything that resembles a Pine Sol smell. You might try boiling a small piece too and see if you get that smell that way. Boiling it would be more likely to release the resins inherent in conifers. If not then it probably is okay to use after following the rest of the instructions in the article.
post #14 of 26 (permalink) Old 09-17-2018, 02:10 AM
https://www.aquariumspace.com/thread...riftwood.4060/
Stick486 is offline
post #15 of 26 (permalink) Old 09-17-2018, 02:39 AM
Great link, Stick! Lots of good stuff in there as well as the comments.
I was thinking about the "bleach" part of the article, and it occurred to me that an excellent alternative would be H2O2...Hydrogen peroxide.
You can get it from the Hydroponics supply shops in 30% solution...that is too potent. A 1:10 dilution rate would give you pretty close to the drugstore stuff (3.5%).
Set up a narrow trough with plastic sheeting and soak the driftwood overnight. Then do the clean water washing.
Ain't nuthin' going to survive that!
Do NOT get it on your skin at the undiluted rate! You will not be happy.
DaninVan is offline
post #16 of 26 (permalink) Old 09-17-2018, 03:34 AM
beauty supply outlets have up to 50% strength...
Stick486 is offline
post #17 of 26 (permalink) Old 09-17-2018, 03:50 AM
The 30% stuff is around $25Cdn for 4 liters. That makes a lot of drugstore type solution.
Best part is after you're finished with it you water it down to about 1% and use it in your garden.
DaninVan is offline
post #18 of 26 (permalink) Old 09-17-2018, 04:09 AM
50% can be had in 250ML sizes through up to 4L
Stick486 is offline
post #19 of 26 (permalink) Old 09-17-2018, 11:09 AM
Don't quote me on this, but I don't think you can buy the 50% up here. There was a major rethink, post 9/11, and what I heard was that there were security concerns about H2O2 being available as an ingredient for explosives.
At that time the hydroponic concentrate was being sold at a 35% rate, then they removed it and subbed the lower concentrate. But then it's Canada, any weirdness is possible...
DaninVan is offline
post #20 of 26 (permalink) Old 09-17-2018, 01:16 PM
JOAT's Avatar
First Name: Theo
Hmm, beauty supply outlets? And just 'why' is it you would know about beauty supply outlets?
JOAT is offline
Identifying Driftwood colleenb Wood Species 6 11-05-2018 02:26 AM
Identifying Driftwood ipoduke Starting Off 3 08-13-2014 01:40 AM
Identifying driftwood peterrum Wood Species 19 07-24-2012 02:26 AM
How to make Driftwood TheOakDude Tools and Woodworking 0 11-28-2011 02:17 PM
