Ash, Who Knew? - Router Forums
 48Likes
post #1 of 26 (permalink) Old 09-09-2019, 08:37 PM Thread Starter
sreilly's Avatar
First Name: Steve
Default Ash, Who Knew?
So I messed up the 2 pieces of 1" thick maple I needed for my 3-in-1 supports so it was off to the wood yard after getting my broken molar repaired....Couldn't find any 5/4 soft maple and the 6/4 was more than I needed both in width and length so I got a nice piece of 5/4 hard maple which looks great after running it on the jointer as then the planner. Of course after the first pass on the planer I decided it was a good time to replace the cutters (helix head) and used a small brass brush (like a tooth brush) to clean the cylinder from saw dust and debris so the cutters would register properly. Next pass was way nicer. But no surprise there.
No my surprise was when I ran a board of Ash that I had gotten. As I was looking for that maple I needed I came across a pile of Ash. I've heard of it of course but never worked any of it. Wasn't sure but thought it was a hardwood which I confirmed. But what it looked like in the rough wasn't all that impressive but now that I ran the jointer on one side to flatten and one edge I was a bit impressed. But hold the presses....next the planner and man that stuff looks great. I can't wait to come up with a project for this, maybe a cabinet for my hand planes...
First 2 are ash and the second is hard maple. I noticed those circular features in the maple and regardless of the feed direction on the planer it looks like they'll need the scraper.
kp91, harrysin, jw2170 and 6 others like this.
sreilly is offline
post #2 of 26 (permalink) Old 09-09-2019, 09:55 PM
I'm fond of Ash. Nice light wood. Cuts and joins well. That's a particularly pretty chunk.
DesertRatTom is online now
post #3 of 26 (permalink) Old 09-09-2019, 10:19 PM
Great wood, and the piece you picked out has supurb grain.
Herb Stoops is online now
post #4 of 26 (permalink) Old 09-09-2019, 11:17 PM
Inor's Avatar
I have a great piece of ash sitting in my shop. It is 12/4 thick (rough sawn), about 10 inches wide and 10 feet long. I bought it because it was really cheap - about $30. I have no use in mind for it and frankly, am kind of scared to cut into it for fear of ruining it. I am pretty sure there is some pretty special grain sitting under that rough cut, but... I have never worked ash before.
Oh well, Andy Rooney (the commentator on 60 Minutes in the 70's and 80's) had over 1500 board feet of hardwood stacked in the racks of his shop for no other purpose than to go look at it once in a while. Maybe that is what this is for too?
DaninVan, MYB and Herb Stoops like this.
Inor is offline
post #5 of 26 (permalink) Old 09-10-2019, 12:52 AM
That is funny. Wood is to make things. Do you have the tools to plane and resaw some of it? It is really strong wood, they make BB bats and axe,shovel,hammer handles out of it, Tables and chairs too.
Inor likes this.
post #6 of 26 (permalink) Old 09-10-2019, 06:17 AM
treat it like oak..
Herb Stoops and Inor like this.
post #7 of 26 (permalink) Old 09-10-2019, 06:54 AM
hawkeye10's Avatar
First Name: Don
I work with Ash quite a bit as well as hard maple. That is some really bad tear out you have in the maple. Try taking some very light cuts and run it threw the planer with the grain if you can. Investing in a carbide cutter for your planer will really help with tear-out.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 26 (permalink) Old 09-10-2019, 08:31 AM Thread Starter
sreilly's Avatar
First Name: Steve
Sounds like a fireplace mantle to me......just saying. Of course if you don't have a fireplace I could tell you how it looks and send pictures
jw2170 and Inor like this.
sreilly is offline
post #9 of 26 (permalink) Old 09-10-2019, 08:36 AM Thread Starter
sreilly's Avatar
First Name: Steve
When I first ran the board through the planner I saw that and immediately changed out the cutters for the carbide ones I bought last Christmas. I had been waiting for a sign that the HSS cutters were getting bad. This was a good enough reason to change them. Light passes at 1/64 - 1/32 in either direction yielded the same results so I figured I'd need to use the scraper to finish or a high angle plane. For now it's sitting on the partially dressed rack.
sreilly is offline
post #10 of 26 (permalink) Old 09-10-2019, 02:31 PM
Wildwood's Avatar
Country: South Africa
First Name: Rob
I like Ash a lot - it was my wood of choice when I was commissioned to make a folding easel. I found an excellently detailed plan on line, as I had never made a folding easel before. The easel was delivered today.
jw2170, DaninVan, TenGees and 4 others like this.
Wildwood is offline
