Is this Oak? If so what Kind - Page 2 - Router Forums
 5Likes
post #11 of 16 (permalink) Old 10-02-2019, 05:50 PM
kp91's Avatar
First Name: Doug
the dark spots are probably oil, based on their previous use.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #12 of 16 (permalink) Old 10-02-2019, 06:16 PM
First Name: Larry
The spots look like something has soaked in to the wood. It follows the pours. Oil? Water in contact with steel?
Dunnage is often not kiln dried or at least not very well.
Larry42 is offline
post #13 of 16 (permalink) Old 10-02-2019, 09:13 PM Thread Starter
Originally Posted by gmercer_48083 View Post
Aj, If you take a 4" piece of red oak and dip one end in water, then blow on the other end... Bubbles will appear in the water. White oak will not.
Neat trick, will definitely have to try that one.
Originally Posted by Nickp View Post
The bottom three pics look like red oak...porous enough...
EDIT...nope...changed my mind...white oak...
first two pics are the same piece which I think was decided on to be white oak. last two pics are of red oak I believe but could be wrong. here is a great site that I came across for wood species. Y'all may know of it already. The (HobbitHouse)
That makes since. Would appear as so. Doesn't really have a smell though. Would those pieces be trash or still usable. Moisture in the stock is near 8% last I checked.
aj21 is offline
post #14 of 16 (permalink) Old 10-02-2019, 09:52 PM
kp91's Avatar
First Name: Doug
The only problem might be whether or not it would take a finish on the oily spots. Try a test first.
jj777746 likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #15 of 16 (permalink) Old 10-02-2019, 11:08 PM
gdonham1's Avatar
First Name: Guy
Be very careful with pallets that come from over seas. Many times they spray them with nasty pesticides. Also most pallet wood even oak is green wood. So be sure to measure moisture content before using to build a masterpiece. If it is domestic (USA) you can use to make a lot of things but if it came from anywhere else be wary and protect your self from noxious chemicals.
gdonham1 is offline
post #16 of 16 (permalink) Old 11-08-2019, 05:44 AM
From the picture, it looks quite different from the hardwood timber.
HeatherWomac is offline
