Mystery wood - Router Forums
 17Likes
post #1 of 20 (permalink) Old 04-10-2020, 03:27 PM Thread Starter
Forum Moderator
difalkner's Avatar
First Name: David
Default Mystery wood
A while back a friend gave me a fair amount of lumber just to get it out of his way and I was happy to take it!
To my knowledge it was Walnut, African and Honduras Mahogany, Maple, and Cherry. Yesterday I cut into a board that I thought was African Mahogany. But when I cut into it the shop filled with an acrid odor almost like pesticide. So now I'm not certain what this wood is but it looks like African Mahogany.
It weighs slightly less than Walnut, maybe 10% less, machines well, and is stable.
Any ideas?
Face grain, sanded -
End grain -
Skip planed, no idea what the oil looking spots are -
David
Herb Stoops likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #2 of 20 (permalink) Old 04-10-2020, 03:37 PM
mahogany that has been chemically treated...
Stick486 is offline
post #3 of 20 (permalink) Old 04-10-2020, 04:33 PM Thread Starter
Forum Moderator
difalkner's Avatar
First Name: David
Honestly, Stick, it looks like African Mahogany but I have no idea what it might have been dipped in or what might have gotten on it. If chemically treated, why, I wonder...?
David
David
Romans 3:23
post #4 of 20 (permalink) Old 04-10-2020, 05:21 PM
David
I thought it looked like aged Mahogany too..
mostly it's insecticides/pesticides, many of which are banned in this country, to control infestations of something....
treat it as hazardous waste..
Stick486 is offline
post #5 of 20 (permalink) Old 04-10-2020, 06:22 PM Thread Starter
Forum Moderator
difalkner's Avatar
First Name: David
Never mind. I just got a call from the guy who gave me all the wood and he said it's Spanish Cedar and that every piece he's ever worked smells like that and he can't stand it. That's the reason he gave it to me! LOL!
David
David
Romans 3:23
post #6 of 20 (permalink) Old 04-10-2020, 06:25 PM
Bstrom's Avatar
First Name: Brian
So is it toxic to you? I’ve gotten some Spanish Cedar from the local Woodcraft and it has no odor...
Common Man Woodworking
Powell, TN
Bstrom is offline
post #7 of 20 (permalink) Old 04-10-2020, 06:44 PM
same here...
Stick486 is offline
post #8 of 20 (permalink) Old 04-10-2020, 06:54 PM
that's not Spanish cedar...
Common Name(s): Spanish Cedar, Cedro
Scientific Name: Cedrela odorata
Distribution: Native to Central and South America and the Caribbean;
also grown on plantations
Tree Size: 65-100 ft (20-30 m) tall, 3-5 ft (1-1.5 m) trunk diameter
Average Dried Weight: 29 lbs/ft3 (470 kg/m3)
Specific Gravity (Basic, 12% MC): .38, .47
Janka Hardness: 600 lbf (2,670 N)
Modulus of Rupture: 10,260 lbf/in2 (70.8 MPa)
Elastic Modulus: 1,323,000 lbf/in2 (9.12 GPa)
Crushing Strength: 5,860 lbf/in2 (40.4 MPa)
Shrinkage: Radial: 4.1%, Tangential: 6.2%, Volumetric: 10.2%, T/R Ratio: 1.5
Color/Appearance: Heartwood is a relatively uniform light pinkish to reddish brown; colors tend to darken with age. Random pockets of gum and natural oils are commonly present. Grain patterning and figure tends to be somewhat bland.
Grain/Texture: Grain is straight or shallowly interlocked. Medium texture and moderate natural luster.
Endgrain: Can range from ring-porous to diffuse-porous; medium-large earlywood pores, small-medium latewood pores; solitary and radial multiples of 2-3; mineral deposits (red gum) occasionally present; growth rings distinct due to terminal parenchyma in diffuse-porous samples, or lines of larger pores in ring-porous samples; rays usually visible without lens; parenchyma banded (terminal), apotracheal parenchyma diffuse-in-aggregates, paratracheal parenchyma vasicentric.
Rot Resistance: Spanish Cedar ranges from durable to moderately durable regarding decay resistance, and is also resistant to termite attack; the wood is also reported to have excellent weathering characteristics. Older, slower-growing trees from the wild tend to produce wood that is more durable than wood from younger, plantation-grown trees.
Workability: Spanish Cedar is easy to work with both hand and machine tools. However, due to its low density and softness, Spanish Cedar tends to leave fuzzy surfaces if not machined with sharp cutters; extra sanding up to finer grits may be required to obtain a smooth wood surface. Also, natural gum pockets can remain wet and may ooze out onto the surrounding surface, which can clog and gum up saw blades, and make finishing the wood a challenge.
Odor: Has a distinct, lingering, cedar-like scent; this characteristic of the wood makes it a favorite for cigar boxes.
Allergies/Toxicity: Although severe reactions are quite uncommon, Spanish Cedar wood dust has been reported as a respiratory irritant. See the articles Wood Allergies and Toxicity and Wood Dust Safety for more information.
Common Uses: Veneer, plywood, cabinetry, musical instruments, (flamenco and classical guitars), humidors, and boatbuilding.
Comments: A historically valuable Latin-American timber, Spanish Cedar has been exploited in many regions, and the species is now considered to be vulnerable according to the IUCN. It’s also listed on the CITES Appendix III for the countries of Brazil, Bolivia, Columbia, Guatemala, and Peru. (It’s listing in Appendix III simply means that the countries listed have voluntarily chosen to control the exporting of the wood, and have sought the cooperation of other countries to help in enforcing these restrictions.) Spanish Cedar may still be freely exported from other Latin American countries not listed in Appendix III.
Not a true cedar, Spanish Cedar is actually more closely related to true Mahoganies (Swietenia and Khaya genera), as both are in the Meliaceae family. Density and mechanical properties can vary widely depending on country of origin and growing conditions; (specific gravity can vary from .30 to as high as .60 in some instances). Some of the wood available at present comes from plantations: where younger, faster-growing trees, produce wood that is lower in density, and paler in color than wood cut from trees taken from forests in the wild.
Danman1957 likes this.
Stick486 is offline
post #9 of 20 (permalink) Old 04-10-2020, 06:59 PM Thread Starter
Forum Moderator
difalkner's Avatar
First Name: David
It looks like the center photo, Stick. But it has a horrific odor, truly like pesticides. Either way it's outside and I'll give it to our mailman tomorrow. Sandy can't stand the odor so I don't need it here.
David
David
Romans 3:23
post #10 of 20 (permalink) Old 04-10-2020, 07:08 PM
David
does the mailman know how well you like him???
Stick486 is offline
