Raw walnut slabs - Router Forums
post #1 of 15 (permalink) Old 10-03-2009, 11:19 PM Thread Starter
First Name: Mike R
Default Raw walnut slabs
I got some freshly cut black walnut from a guy down the street. Mostly the edges but some cuttoffs and some slabs. See attached pics.
The question is how do I cure it for the best results? My plan is to cut it into small pieces for projects once it is cured.
I live in the high desert so very low humidity and fairly dry winters. I am thinking just stack it in my crawl space and leave it for a couple years...?
Realy don't have a clue as I have never delt with fresh cut hardwood.
awoodnut is offline
post #2 of 15 (permalink) Old 10-03-2009, 11:48 PM
RStaron's Avatar
First Name: Ron
My dad dried his own Oak. He stacked it under a metal roof to keep the rain and snow off. He stickered it, pieces of 1x1 between each board for air flow, and let it dry until he almost used up what he had in the basement. Then he took some and stacked it in the basement the same way, covered it with plastic and ran a heat duct to it thru the winter. This did a pretty good job of drying it. Not like Kiln dried, but almost. I did shrink and expand with the seasons on the doors he made for his basement storage cabinets. Ther is something you can paint on the ends of the boards to keep them from cracking as they dry but I can't remember what it's called. Hope this helps.BTW he lived in central Wisconsin.
RStaron is offline
post #3 of 15 (permalink) Old 10-03-2009, 11:55 PM
curiousgeorge's Avatar
First Name: George
Mike, here is an article from finewoodworking.com on how to air dry lumber. You have to be a member to view the PDF, but they have a 14 day free trial you can use to view the article. I'm certain there are even more articles there on this subject, but this was just the first one I found while searching.
Click Here
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 15 (permalink) Old 10-04-2009, 12:26 AM
xplorx4's Avatar
First Name: Jerry
On the ends just use paint, anything to seal the ends. When you stack the lumber, the 1x1 separators’ need to be directly under one another that is so the weight is transferred directly to the ground and not on another board causing it to warp. Air drying will get it to about 12% kiln drying will get it to 8% but will rise when taken out of kiln to about 12%, at least here in Georgia that is the case. I am just learning about this and will know more after next week.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 15 (permalink) Old 10-04-2009, 11:56 PM Thread Starter
First Name: Mike R
Default drying
Thanks guys
I will get something on the ends and get it stickered. I have a larg walk area under my house so I will put it in there. Dirt floor but stays dry and well above freezing in the winter.
I will look at that artical. I have been meaning to take the free trial and look at there hand cut dove tail vidio.
Jerry, you said you will know more next week. Are you taking a class or what? I will look forward to hearing what you learn.
Thank
awoodnut is offline
post #6 of 15 (permalink) Old 10-05-2009, 09:44 PM
RustyW's Avatar
First Name: Rusty
Mike, you may have all ready seen these, but theres a good hand cut dovetail video on this page. Along with 40 other videos,and there all free.
http://www.woodworkingonline.com/category/podcast/
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #7 of 15 (permalink) Old 10-06-2009, 01:07 AM Thread Starter
First Name: Mike R
Thanks Rusty, I did see that one. I appreciate the tip, always looking for more.
It's interesting see everyones little bit different way of doing it and then trying to make sense of it all. I started cutting some and it didn't come out bad. I like marking them kind of by eye and just picking an angle and a spacing that looks good.
awoodnut is offline
post #8 of 15 (permalink) Old 10-06-2009, 05:00 PM
First Name: Duane
Doesn't it take a long large time to air dry ?
Duane867 is offline
post #9 of 15 (permalink) Old 10-06-2009, 11:06 PM Thread Starter
First Name: Mike R
Hi Duane
I was hopeing to figute out how long from somebody hear.
I am thinking at least a couple years.
awoodnut is offline
post #10 of 15 (permalink) Old 10-07-2009, 07:50 PM
drasbell's Avatar
I'm sticker drying some maple and was told to expect at least 1 year of drying time per inch
Life: Is a runaway train you cant wait to get on.
drasbell is offline
Walnut Desk rprice54 Show N' Tell 30 04-22-2015 07:34 AM
Zebrawood / Walnut Box Build Alongť Nickbee Show N' Tell 39 06-21-2009 07:18 PM
Bleedback and walnut????? Nickbee The Finishing Touch 4 02-21-2008 09:22 AM
Prepping Walnut Burl Veneer for finishing? Nickbee The Finishing Touch 1 01-24-2008 10:24 AM
Walnut Burl Veneer… What kind of glue? Nickbee Tools and Woodworking 7 01-19-2008 09:56 AM
