brazillian red wood - Router Forums
post #1 of 15 (permalink) Old 10-19-2009, 10:18 PM Thread Starter
First Name: Mike R
Default brazillian red wood
Got some brazillian Red wood and I am trying to find info on glueing and finishing.
I went thru a bunch of info on the internet and it mentioned it may have problems glueing but no suggestions on how to solve this problem. Also a UV protectant finish was suggested.
Has anybody worked with it and do you have any suggestions?
I started milling it and the dust is really hard on the sinuses. Had to use a dust mask. Also the red dust is every where in the shop.
Any help is apperciated.
awoodnut is offline
post #2 of 15 (permalink) Old 10-20-2009, 09:41 AM
drasbell's Avatar
I have not ever seen that a photo would be nice if you could. and good luck with your project
did a quick search and came up with this hope it helps.
http://www.simmenlumber.com/brazilian_redwood.html
The Wood Explorer Database.
Life: Is a runaway train you cant wait to get on.
drasbell is offline
post #3 of 15 (permalink) Old 10-20-2009, 11:31 PM Thread Starter
First Name: Mike R
Thanks Rick
I did see the first one, the second I hadn't but agean they mention being difficult to glue but no mention of the solution.
I will post a picture shortly.
awoodnut is offline
post #4 of 15 (permalink) Old 10-21-2009, 02:31 PM
drasbell's Avatar
As far as gluing procedures I have looked and came up with nothing, My suggestion is if you have enough wood I would mill a few small pieces and try different gluing techniques like butt joints edge gluing and miter or half lap and see what happens using your normal glue Good luck and let us know...
drasbell is offline
post #5 of 15 (permalink) Old 10-21-2009, 04:00 PM Thread Starter
First Name: Mike R
Default Pics of wood
Came up with one site last night that suggested a high quality water proof glue or epoxy. I will do some sample glueing and see what works.
awoodnut is offline
post #6 of 15 (permalink) Old 10-21-2009, 07:32 PM
drasbell's Avatar
nice looking stuff I can already see the wheels turning...
drasbell is offline
post #7 of 15 (permalink) Old 10-21-2009, 07:37 PM
HI Mike
I have used the items below and it works very well
Wipe the stock down with the alcohol and then let it dry and then put the glue in place, let it dry over night..
post #8 of 15 (permalink) Old 10-21-2009, 10:34 PM Thread Starter
First Name: Mike R
Default Poly glue
Thanks Bob
I will see what I can find localy tomorow. Is that stuff from HD or Lowes?
awoodnut is offline
post #9 of 15 (permalink) Old 10-21-2009, 10:41 PM
Hi Mike
I got it from HD,the Alcohol from the drug store..
by the way this stuff works on
(Ultra High Molecular Weight Polyethylene)
UHMW to make jigs and fixtures for your table saw , router table, etc.
UHMW Polymer (plastic) is a linear polyethylene with a molecular weight in the range of 3,000,000 to 6,000,000. This value represents the "average molecular weight". Therefore UHMW is 10 times heavier than regular high density polyethylene.
http://www.ptreeusa.com/uhmwproducts.htm
Thanks Bob
post #10 of 15 (permalink) Old 10-22-2009, 05:54 PM Thread Starter
First Name: Mike R
Default umhw ?
Bob is that what the old cutting boards are made out of ?
Old cutting boards and some Plexy glass I was given are the only things I have used so far.
awoodnut is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 01:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 08:40 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 06:58 PM
Questions about wood Pallets and moisture GoonMan Tools and Woodworking 2 07-05-2005 08:11 PM
