Eucalyptus (Paperbark Gum?) - Router Forums
post #1 of 13 (permalink) Old 09-09-2010, 02:33 AM Thread Starter
Country: Spain
First Name: Ray
Unhappy Eucalyptus (Paperbark Gum?)
I live near the sea in Northwest Spain, where, due (so I'm told) to a misguided initiative in the Fifties or thereabouts, the Franco Government encouraged the planting of Eucalyptus.
Seeding as they do so well here,(plenty of rain in Galicia!) the have really 'taken over' in many areas.
As I have never used this timber except as posts, can anyone ( I'm thinking particularly of our Australian members) advise on the practical uses and possible snags about this timber?
Ray
RayArdia is offline
post #2 of 13 (permalink) Old 09-09-2010, 06:20 AM
Gene Howe's Avatar
First Name: Gene
Ray
Not being any kind of tree expert, I'd guess that Eucalyptus grown in Spain or Australia is probably not the same as what Americans call Eucalyptus.
But then it might be, too.
With that disclaimer, I can say that the pieces of American Eucalyptus I have worked have been fairly soft, easy to shape and requiring judicious sanding. Comparable to Poplar. Most I've seen doesn't grow tall enough to yield much usable timber. But, it must grow tall somewhere because I've seen long boards in lumber yards.
Why not grab a piece and try it out?
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 13 (permalink) Old 09-09-2010, 08:38 AM
dutchman 46's Avatar
First Name: Howard
Hello Ray? I do no know my trees, but I would like to see a picture of one. I know it takes a bit, but You can do it. The tree can be checked if You know the proper name for the tree. and check with an expert on the web .
John 3:16
dutchman 46 is offline
post #4 of 13 (permalink) Old 09-09-2010, 09:47 PM
Ray
Hi Ray,
paperbark tree can be any of the more than
200 species belonging to the genus Melaleuca
in the family Myrtaceae, which are mostly endemic
to Australia.
Paperbark and Eucalyptus are two different species.
You would need to find the proper scientific name of the tress you are asking about.
Sydney, Australia
jw2170 is offline
post #5 of 13 (permalink) Old 09-10-2010, 08:16 AM
Harry,
I believe your renowned Jarrah is a Eucalypt.
Sydney red gum , Etc,
Sydney, Australia
jw2170 is offline
post #6 of 13 (permalink) Old 09-10-2010, 08:22 AM
But then it might be, too. ry it out?
Hi Gene
re:fairly soft, easy to shape and requiring judicious sanding.
Some of our Eucalypts are some of the hardest timbers to work eg Ironbark? ( not called that for nothing)
However there are some beautiful timbers suitable for furniture making.
Even some of the Californian Eucalypts were from Australia as they are a quick (relatively) growing hardwood.
Sydney, Australia
jw2170 is offline
post #7 of 13 (permalink) Old 09-10-2010, 09:11 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by jw2170 View Post
Harry,
You are so right James, our West Australian Jarrah is indeed one of so many types of Eucolypts, and a VERY hard one at that, much sought after for furniture making leaving very little quality boards available for the hobbyists who can afford to buy it!
Harry
harrysin is offline
post #8 of 13 (permalink) Old 12-25-2010, 12:35 PM
First Name: Wayne
Default Paperbark vs. Eucalyptus
I see this is a somewhat older thread, but here in Florida the paperbark Melaeluca is considered a weed tree, an invasive species. Land speculators seeded the Everglades and other swampy areas, for which Florida has no shortage, from airplanes. The hope of the land barons was that the trees would slurp up all of the water and create dry land, which didn't happen.
To this day, it is a common sight to see county workers and homeowners having these trees removed. There is a plentitude of the paperbark to be had here. If it is easy to work, save for the sanding, I would not be opposed to using it. It does give off a somewhat offensive odor. Have any of you worked with it and if so, what kind of project would you recommend it for?
Sweeneyastray is offline
post #9 of 13 (permalink) Old 01-04-2011, 10:41 PM
In Southern AZ Eucalyptus grows well. I made a bench from a 10" diameter log, connecting the back, legs, and arms to the seat with 3/4" copper pipe. The blades/bits used for drilling where basic consumer level products. This wood was so hard to drill through that it burned every tip out. None were usable after the project. I would suggest using a better bit set then I did. But it was worth the all the hardships. The heart wood takes on a beautiful copper tone and the otter wood a soft brown (at least in my corner of the world). Enjoy
nyazjaz is offline
post #10 of 13 (permalink) Old 01-05-2011, 07:43 AM
gav
Country: Croatia
First Name: Gavin
If it is actually paperbark, it should be obvious because it has a very distinctive flaky papery bark. Like in the picture below.
Apparently it's good for wood turning as it has a dense grain but it splits easily when drying.
Take a picture of one of the trees and post it here.
gav is offline
bit gum cleaner ktaustins Router Bits - Types and Usage 12 03-30-2010 12:44 AM
My gum ball machine vikingcraftsman Show N' Tell 23 12-28-2009 10:26 AM
help with a nail gum h_porta Starting Off 2 02-02-2009 06:22 PM
Peppermint Gum nzgeordie Tools and Woodworking 0 08-09-2008 09:09 PM
