Burn marks on Cherry end grain - Router Forums
post #1 of 3 (permalink) Old 03-11-2011, 03:43 PM Thread Starter
RJH
First Name: Russ
Question Burn marks on Cherry end grain
How do I reduce the amount of burn marks on the end grain of Cherry?
RJH is offline
post #2 of 3 (permalink) Old 03-11-2011, 04:27 PM
Phil P's Avatar
First Name: Phil
Other than correct RPMs for the size of cutter make sure that your cutter is nice and sharp and that you have dust extraction. Also helps if the cutter hasn't been sharpened too often as that can reduce back clearance.
Phil P is offline
post #3 of 3 (permalink) Old 03-15-2011, 03:06 AM
G'day Russ
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
Ski question os smoothing end grain, bit, speed, etc TanOak Portable Routing 4 11-07-2010 09:03 AM
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 08:32 PM
Staining end grain rstermer The Finishing Touch 11 02-21-2009 08:22 AM
End grain burn!!! dkneifel General Routing 2 12-18-2008 02:30 PM
